03 GT making bad knocking noise??? - Mustang Evolution
Old 02-19-2014, 04:55 PM   #1
Jgrummz's Avatar
I have a 2003 GT (5 speed) that is making a bad knocking noise when i go over bumps and when i start out in first gear. Its doesn't do it every time i go over a bump and it also doesn't do it every time i start out in first. It probably happens about 75% of the time. Does anyone know what could be causing this?
Here is a video when it makes the sound starting out in first gear.
Jgrummz is offline   Reply With Quote
Old 02-19-2014, 09:39 PM   #2
04beautyGT's Avatar
It's hard to make out from the video which noise you are talking about, but to me it doesn't sound like a "knock". It sounds like something loose under the car. Are you sure it's coming from the engine?
04beautyGT is offline   Reply With Quote
Old 02-19-2014, 09:53 PM   #3
Jgrummz's Avatar
Its only at the very beginning of the video and no i dont think its something with the engine i think its something with the suspension
Old 02-20-2014, 12:04 PM   #4
04beautyGT's Avatar
Sorry, I can't really tell. Only thing I can do is advise getting under there and shaking things around, it sounds like something is loose. To me it sounds like something with the exhaust, like maybe hitting the underbody and that's why it only happens over bumps or in first gear (first gear is when your exhaust pipes shake the most.) It sounds like you have aftermarket exhaust, maybe it wasn't installed exactly right.
Hopefully other people have some different ideas.
Old 02-20-2014, 12:48 PM   #5
Jgrummz's Avatar
Ok thanks a lot man
Old 02-20-2014, 12:54 PM   #6
Screaming Mach's Avatar
Is it your rear control arm bushings?
Screaming Mach is offline   Reply With Quote
Old 02-20-2014, 03:05 PM   #7
Jgrummz's Avatar
To me it sounds like its coming more from the front of the car but idk i could be wrong.. It can be kind of hard to tell sometimes
Nasty noise under the hood please help! S197STANG 2005-2010 Mustang GT 18 11-05-2011 10:14 PM
2006 GT 350 theivanoff 2005-2010 Mustang GT 15 09-20-2011 05:16 PM
Clutch noise 02 mustang gt mkw037 1996-2004 Mustang GT 5 09-05-2011 08:14 AM
2011 V6 versus 2012 GT 5.0 avengnd General Mustang Discussion 6 09-01-2011 04:49 AM
03:46 PM
