Spark degrees - Mustang Evolution
Old 02-21-2014, 10:11 AM   #1
1lowGT's Avatar
Spark degrees
On the my livewire tuner you can adjust spark and what not
spark 0-2000rpm --- 0 degrees
spark 2000-4000rpm --- 0 degrees
spark 4000-8000rpm --- 0 degrees
Thats what they are set on obviously. Question is what will it to advance/****** it i want to know if it helps or not. Please someone who knows what they are talking about.
Old 02-21-2014, 11:12 AM   #2
I find it hard to believe that your tune is keeping the timing at 0 degrees all through the RPM range.
Generally speaking though, advancing the timing will give you more power but you'll have to run a higher octane fuel. Retarding does the opposite.
This is the part in the tune that changes between a 87 octane tune and a 93 octane tune, with the A/F ratio to match.
Old 02-21-2014, 01:15 PM   #3
1lowGT's Avatar
Name:	ImageUploadedByMustang Evolution1393013632.250754.jpg
Just running stock tune for now. Too lazy to get my other tunes downloaded. Whenever I get around and do it illcheck the custom tunes. I'm running 91 for now until I get my 93 tunes
Old 02-21-2014, 05:31 PM   #4
DaBluedude's Avatar
The 0 degree marker is from the base settings from the tune. Not what the tune has the timing set to. I would just leave it alone if the car is running well. I have mine ser to -1 from 4kto8k in my Mach because I get a tiny bit of pinging otherwise.
2003 Mach 1
« WOT A/F | HELP »
spark plug question ebgonzalez1 2011-2014 V6 Mustang 29 04-12-2013 03:51 AM
used 98 mustang and new spark plugs Deadpool Pre-2005 V6 Mustang 4 11-02-2011 10:09 PM
120,000 mile spark plugs? Just_John Pre-2005 V6 Mustang 2 10-08-2011 09:43 AM
E3 Spark Plugs Diamond Fire - Spark Plug gonzo56 2005-2010 V6 Mustang 6 09-28-2011 09:45 AM
04:35 AM
