Mustang IRS - Mustang Evolution
Old 02-23-2014, 08:20 PM   #1
Mustang IRS
How to put IRS on a 2004 mustang gt? How much would that cost
chrisharris12 is offline   Reply With Quote
Old 02-23-2014, 08:24 PM   #2
Mile high JDF's Avatar
Do you plan on paying a shop to do it? I would plan a day to swap it in. Just gotta find a Cobra owner who wants an SRA
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 02-23-2014, 08:34 PM   #3
It bolts directly in place. The only change that is needed is pinion flange or end of driveshaft
Sent from my massive johnson.
Old 02-23-2014, 08:46 PM   #4
I would want it done professionally..
Old 02-23-2014, 09:26 PM   #5
I have no clue of a shop would install that for you. Maybe find a custom shop?
Old 02-24-2014, 07:19 AM   #6
Figure 4-5 hours billable labor. I don't know what the shops in your area would charge. I've done swaps in a few hours in my garage.
Old 02-24-2014, 07:19 AM   #7
You'd have to find a Mustang shop that knows what you are talking about. You need a complete IRS, you need the pinion flange from the DS and you need a IRS catback. If you do find a shop that will do it prepare to lube up. Figure $1200-$1500 shipped from ebay or a forum member for the IRS, $50 for the flange, $400 for a cheaper catback and then whatever the labor rate is if you can find a shop to do it. Then there is the fact that you'll get massive wheel hop and deflection with the stock rubber bushings. Another $700 to get the FTBR Delrin kit and the labor to put that in too before you bolt the IRS into place.
I'm not trying to dissuade you from this swap, I'm just letting you know what you are in for $$ wise. And like I said you'll have to find a Mustang or speed shop that will even do this.
Old 02-24-2014, 07:20 AM   #8
Slow4V's Avatar
Id say like 500-700 for the swap if the shop does it
Old 02-24-2014, 07:23 AM   #9
I'm still of the opinion when you start getting into swaps like this if you aren't going to do it yourself you probably shouldn't bother.
Old 02-24-2014, 07:23 AM   #10
Slow4V's Avatar
Exactly ^
How to: 4.2L V6 Mustang Engine Swap Danger Dude Pre-2005 V6 Mustang 85 11-14-2015 07:51 PM
AmericanMuscle Carries Injector Dynamics Mustang Fuel Injectors AMWill AmericanMuscle 0 01-31-2014 03:04 PM
07:18 AM
