Play in steering - Mustang Evolution
Old 02-25-2014, 08:12 AM   #1
Kbasham5's Avatar
Play in steering
Hey guys. Hoping someone can help me out. I just replaced my steering column in my 01 GT now I am getting about and inch play in my steering. Before I changed columns my steering was tight. What could be up with the column that would cause play in the steering? Thanks for your help.
Kbasham5 is offline   Reply With Quote
Old 02-25-2014, 01:17 PM   #2
DutchManDann's Avatar
What did you replace it with,Aftermarket, OEM? And where did you get the replacement shaft? And also why did you do the replacement?
Usually play in the steering is caused by the rag joints on the shaft having some play in them. They are supposed to be a little loose from the factory to decrease NVH. A stock mustang will have about an inch of play back and forth before the wheels will actually turn
Roxanne- 1998 Mustang GT Convertible: 5-Speed, 2001 PI 2V swap, o/r h-pipe, Magnaflow catback, MGW shifter,
3.73 gears, Auburn LSD, TA diff cover, MM FLSFCs, Ford Strut Tower Brace, J&M SS Brake Lines, and a lot of visual/restoration work.
DutchManDann is offline   Reply With Quote
Old 02-25-2014, 03:33 PM   #3
Kbasham5's Avatar
My clock spring went out and a buddy of mine had a steering column laying around so I just put the steering column he gave me in my car. It just seems to have more play in it than my original one did.
sloppy steering on the highway. 94gtconvert 1979-1995 Mustang GT 9 03-02-2014 09:24 PM
Wandering Steering, Please Help Michael.s.king General Mustang Discussion 7 02-11-2014 01:19 PM
Steering resistance is different turning left vs right CUBuffalo 2011-2014 V6 Mustang 6 01-22-2014 07:13 PM
Steering decision help Rockn69Stang Classic Mustangs 2 10-31-2011 06:14 PM
Ditching power steering? Stang.racr 1979-1995 Mustang GT 4 08-24-2011 02:36 PM
01:35 PM
