FRPP "B" Springs, with or without isolators - Mustang Evolution
Old 02-25-2014, 01:27 PM   #1
DutchManDann's Avatar
So my tax return is in and i am about ready to pull the trigger on lowering springs.
My plan is to run this setup on my 98 GT Vert:
-FRPP "B" Springs
-No isolators (will wrap spring ends in tape to reduce noise)
-MM C/C Plates
-new struts all 4 corners
What do you guys think of this setup? I am at a loss on whether or not I should run isos or not, I am hoping to get a perfect ride height on the first go.
Roxanne- 1998 Mustang GT Convertible: 5-Speed, 2001 PI 2V swap, o/r h-pipe, Magnaflow catback, MGW shifter,
3.73 gears, Auburn LSD, TA diff cover, MM FLSFCs, Ford Strut Tower Brace, J&M SS Brake Lines, and a lot of visual/restoration work.
DutchManDann is offline   Reply With Quote
Old 02-25-2014, 02:23 PM   #2
larrysgt's Avatar
Heard it drops your car a bit more without isos but also heard they make noise
larrysgt is offline   Reply With Quote
Old 02-25-2014, 03:35 PM   #3
Mile high JDF's Avatar
I had 0 noise issues when running my H&R springs without isolators. How much do the B springs drop?
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 02-25-2014, 03:44 PM   #4
Removing the isolators will drop more, which is why I want to remove them.
The B springs seem to drop about 1.25" in front and a little less in rear. I want a bit of a rake because I think the SN95 body style will look good that way.
I'm just unsure because mines a vert so it's a bit heavier and will drop differently. It's good to know that no isolators hasn't been an issue for you I'm probably not going to run them
Old 02-25-2014, 07:22 PM   #5
I cant comment on the B springs, but I installed the C springs on my 96gt with new isolators and the front was higher than the back. I put the factory worn out isolators on the front and it had a great stance and ride. (Front was slight lower than the back) My 2nd 96gt had eibachs progressive rate and it was a lil lower but couldnt compare to the ride of the C springs.
Bigshow14 is offline   Reply With Quote
Old 02-25-2014, 07:24 PM   #6
Thats with 2000gt factory 17's with 245/45's and 17 inch cobra r's with the same size tires
Old 02-25-2014, 08:50 PM   #7
See now im not sure if I should do the B or C springs...I am thinking B because they are progressive and better for ride quality. And considering mine is a convertible I really don't want springs that are gonna give me a harsh ride
Old 02-26-2014, 08:57 AM   #8
Well I just pulled the trigger on the C springs. After lots of researching and thinking I decided that I likes the way the c springs sit better and I wanted a firmer ride.
I am not going to run isolators and for now I'm not doing c/c plates and I'm going to see how it drives.
Old 02-26-2014, 05:46 PM   #9
larrysgt's Avatar
Confused what are A B C SPRINGS?
Old 02-26-2014, 05:58 PM   #10
BigB227's Avatar
B and C springs, they are lowering springs made by Ford Racing, one is a progressive rate spring and one is a standard rate. They sell them on American Muscle
BigB227 is offline   Reply With Quote
Guy is selling me H&R springs that came off his 95 mustang coupe larrysgt 1996-2004 Mustang GT 4 02-09-2014 12:21 PM
Which springs? RUNNWLD 1996-2004 Mustang GT 62 06-15-2012 06:40 PM
Eibach/Roush/Dub Springs cheap Napoleon85 2011-2014 Mustang GT 27 03-12-2012 11:02 AM
Lowering Springs jjsg09 1996-2004 Mustang GT 14 02-06-2012 06:11 AM
55D Springs on Brembo Brake Mustangs 201150300A 2011-2014 Mustang GT 0 12-13-2011 05:16 PM
05:53 AM
