Is this weird ? - Mustang Evolution
Old 02-26-2014, 07:51 PM   #1
Slow4V's Avatar
Is this weird ?
Okay my buddy has a 99 cobra 4V swapped GT
Mods - Longtubes X pipe Catback
Cold air intake , Tune , 373 Gears , Short throw , decent driver
My Mods - 410s , X pipe
Everytime we run I always beat him by like 2 cars, and I don't understand why
I'm not the best driver but I'm decent too
Old 02-27-2014, 04:58 PM   #2
DutchManDann's Avatar
Is this weird ?
It's because yours is a Mach 1. I don't know the exact details on each car, but the stick Mach 1s made a lot more power than they were rated for from the factory. Not to mention you have upgraded suspension components from the factory in comparison to the GT, and a better transmission. Also your car is lighter weight, due to having an aluminum block 4v.
What year cobra did the 4v swap come out of? That and mileage/how worn out the engine is can also play a factor. He probably has an iron block 4v which is heavier than the Mach 1s.
Mach 1s are ridiculously quick cars
Roxanne- 1998 Mustang GT Convertible: 5-Speed, 2001 PI 2V swap, o/r h-pipe, Magnaflow catback, MGW shifter,
3.73 gears, Auburn LSD, TA diff cover, MM FLSFCs, Ford Strut Tower Brace, J&M SS Brake Lines, and a lot of visual/restoration work.
DutchManDann is offline   Reply With Quote
Old 02-28-2014, 09:22 PM   #3
The 4V in the 99/01 is very slightly lower powered than the 03/04 Mach with the revised heads. Besides that they're identical. Dude with the 99 swapped 4V has like a 160k miles on it though, there is your answer.
Old 03-01-2014, 05:33 AM   #4
The stick Mach 1st also had a forged crank and put out a lot more than the advertised power rating.
Old 03-01-2014, 05:08 PM   #5
Forged crank is not good for any more power in stock trim with the stock powdered rods. That makes no difference. The only difference in the motors is the revised ports on the 03/04 C heads, that is it and it wasn't really a huge difference in power. Like I said, old boy is losing because the guy who swapped that 4V in used a super high mileage motor and this is what happens.
Old 03-03-2014, 07:07 PM   #6
weschris's Avatar
4:10 gears are the difference
02 GT,Ford racing C springs,Tokico rear shocks,Mpr full length subframe connectors,Kyb adjustable front struts,hardened steel axles,3.73 gears,Bbk uppers,Granitelli adjustable lowers, Mach 1 seats,Steeda Tri ax shifter,Exedy stage 2 clutch,Firdanza aluminum flywheel,Bbk adjustable clutch quadrant,Bbk shorty headers ,Mpr catted x pipe,Pypes Violator catback,Jlt cai,Bulitt intake manifold,Venom 24 lb injectors,Ngk iridium plugs,TFS twisted wedge heads and cams,stock short block ,custom dyno tune on a Mustang dyno.
weschris is offline   Reply With Quote
Weird Acceleration noise of 2013 v6 Mustang!!!!!!!Please help!!!! Josephtsai 2011-2014 V6 Mustang 114 03-10-2014 01:39 PM
weird noises woodyusaf 2005-2010 Mustang GT 8 02-19-2013 08:42 AM
Weird noise from shifter v8pony 1996-2004 Mustang GT 54 11-12-2012 02:38 PM
weird noise PLEASE HELP GTKidd53 General Car Discussion 8 12-30-2011 04:50 PM
Any 2011 AT owners out there -- weird throttle response? illestdomer2005 2011-2014 V6 Mustang 5 07-09-2011 12:36 PM
08:49 PM
