2001 Stang won't start without starter fluid - Mustang Evolution
Old 02-27-2014, 05:30 AM   #1
Xaperez100's Avatar
It will only start with starter fluid being sprayed into the throttle.. Fuel pump turns on. New fuel filter. What do you guys think? It's not the sparks there's no misfire.
It starts with starter fluid and you can drive it for as long as you want. And it will start again if it's only been off for less than I'm guessing 2 hours. But after work and sitting there for 8 hours it won't start up..
Xaperez100 is offline   Reply With Quote
Old 02-27-2014, 11:44 AM   #2
You could put a fuel pressure test gauge on it to be sure, BUT, I think that it's safe to say that your fuel pump is in the very last stage of it's life...
RIP Fuel pump.
Old 02-27-2014, 11:48 AM   #3
Xaperez100's Avatar
Haha dang well how much pressure should it have when I check it?
Old 02-27-2014, 12:59 PM   #4
It should be at 35 to 55 psi and and should hold the indicated pressure for 5 minutes with a loss of less than 5 psi.
It's the pressure holding that is probably the problem with your pump...
Old 02-27-2014, 01:02 PM   #5
Xaperez100's Avatar
Okay thanks man it's my friends trying to get this thing started.. Haha if not then what do you think about the fuel injectors? When I pulled the rail away from them only gas came out of the top of one..
Old 02-27-2014, 01:09 PM   #6
FUEL PUMP!!!!!!!!!!!!!!!!!!
Test it if you can, but I'm pretty sure that's the problem.
I have a new one for my car, waiting to be installed, because I've been experiencing the beginnings of the same symptoms you've described. My car has almost 150k miles.
Old 02-27-2014, 01:12 PM   #7
Xaperez100's Avatar
Yeah I'll replace it today :p
Old 03-03-2014, 12:58 AM   #8
Mosified's Avatar
Starter fluid FRIED my IAC. Had to replace it...
Old 03-16-2014, 08:57 PM   #9
Xaperez100's Avatar
Fixed. Was the crank position sensor lmao
Old 03-16-2014, 09:14 PM   #10
Mosified's Avatar
nice gotta love when you nail the culperit!"
Old 03-17-2014, 01:55 PM   #11
WJL
Mos, ever get your car back up and running?
WJL is offline   Reply With Quote
Old 03-17-2014, 01:59 PM   #12
Mosified's Avatar
Oh yeah. I been working on it. thats why i took a lil break from the art.
Check engine soon light came on? KamzGT Pre-2005 V6 Mustang 27 09-14-2013 04:33 PM
Able to start with a voltage meter. uhm.. ?!? Black_Sunshine Pre-2005 V6 Mustang 0 09-07-2012 12:42 AM
Wont Start Balltaatic01 1996-2004 Mustang GT 10 05-07-2012 05:44 AM
Manual Transmission Fluid Napoleon85 2011-2014 Mustang GT 6 11-15-2011 02:47 PM
1966 Do I need a new starter? Mvonraesfeld Classic Mustangs 1 08-12-2011 11:44 PM
08:10 AM
