Need F.I. info. 96 GT with PI swap - Mustang Evolution
Old 03-02-2014, 10:06 PM   #1
Mosified's Avatar
I'd like advice from a M.E. member who installed a blower on thier 96-98 GT PI swapped. I've only read about what Mustang owners will have to do. But it's all hear-say to me. A finished project would be great especially to avoid the "trial on error".
Old 03-02-2014, 10:10 PM   #2
Mosified's Avatar
My mods are FRPP PI assembled heads, PI intake, stock exhaust manifolds, 2.5" X-pype, C.A.I. , 4.10's and BAMA Eliminator Chip. I just got a BBK 78mm TB. (didn't install it yet). Any knowledge will be greatly appreciated
Old 03-02-2014, 10:14 PM   #3
Just throwing this out there, is your compression bump with the pi heads a concern
Bigshow14 is offline   Reply With Quote
Old 03-02-2014, 10:21 PM   #4
Mosified's Avatar
Im sure it's around 10.5:1
Old 03-02-2014, 10:26 PM   #5
Mosified's Avatar
I've read a lot of threads about blowers that can handle the high (for F.I.) compression. I just need to know the set up.
Old 03-03-2014, 09:49 AM   #6
Mosified's Avatar
Pro Charger P-1SC . Anyone running this on thier 96-98?
Old 03-04-2014, 12:55 AM   #7
Mosified's Avatar
OK. So I'm totally talking to myself here. LOL... After hours of research, I found out that Centrifugal SC's with the water/methanol injector (along with other safety precautions) I can run 6-8 lbs of boost. This should give me 350hp safely. By performing all the work myself, I still don't have alot of $$$ into my Stang I found complete SC set ups slightly used in the $1,500 price range.
Old 03-04-2014, 07:23 AM   #8
1996mustang's Avatar
See im interested in this as well now but not only for sc but also turbo setups since pi swap puts it at roughly 10.54:1 very interested in what boost adders we can run either safely and forging bottom end as well
Old 03-04-2014, 09:20 AM   #9
Mosified's Avatar
Forged crank and pistons would solve the "ticking time bomb" problem. Plus, never let the water/methanol tank run dry. Intercoolers and SC cams prevent detonation too. Spark plugs gapped at .35 . New pistons will lower the compression too. I read that thicker head gaskets lower compression too. But I wouldn't do that with new pistons. Once all this is built to the right specs, BOOST AWAY
Old 03-04-2014, 10:44 AM   #10
Mosified's Avatar
100 shot of nitrous should give us at least another 1-1.5 seconds in the 1/4. Suspension and traction to improve 60/ft times could give us another .3 to .4 seconds A proper set up and tune would easily put our 281's in the 12's..
Another t56 swap question jmoon4 Pre-2005 V6 Mustang 0 02-25-2014 01:33 AM
1996 Ford Mustang GT 4.6 auto to Trans swap 5.0orGTFO General Mustang Discussion 5 02-03-2014 04:56 PM
2006 GT 350 theivanoff 2005-2010 Mustang GT 15 09-20-2011 05:16 PM
2011 V6 versus 2012 GT 5.0 avengnd General Mustang Discussion 6 09-01-2011 04:49 AM
3.8L to 4.6L swap info zrider07 Pre-2005 V6 Mustang 14 07-22-2011 11:27 PM
05:17 AM
