Motor rebuild questions - Mustang Evolution
Old 03-04-2014, 08:14 AM   #1
2002VertGT's Avatar
Ok, so a few months ago my 02 gt had a slight ticking at rpms 2500-3500 (after that they got drown out by the exhaust. Checked oil, changed oil, changed timing components, sound just kept getting louder and is now a very prominent tick/slight knock. With that being said I have found a used motor for a very reasonable $325 to swap in there so I can still enjoy her for the time being while I rebuild her motor.
So, is it more cost effective to build a motor for FI or to just buy a motor for it? I have found from MMR complete long blocks capable of holding up to 900hp with trickflow heads and all the goodies for 8400. On the other hand Forged stroker kits are around the 2.5-3k range, however I know that is not all you need to do. I am quite confident that the whole process of having the block cleaned up, bored out, honed and blue printed is going to be somewhere in the 1000-1500 range? cams are another 600. P&P on my heads will be another 600? what about valve jobs not sure on price of those?
I am new to the engine building process so any help will be greatly appreciated. I currently have a Procharger P1SC 3 core intercooler to be used on this motor once its done. Not interested in the centri vs screw sc debate, if I had found a kb at the price i found this centri its what i would have. Not sure on what I need to set my compression at or what size pistons I need to achieve that compression either so any help there would be great too. Let the games begin! My budget RIGHT NOW is undetermined, my tax money is going to putting a motor in my f150 atm because that needs fixed. Over the next year though I plan to tear into the old motor and start the rebuild process if I do not just buy a motor.
As for the "just buy a 4v" guys. Got my eye on that as well. I found a guy selling everything needed to install a 4v and a t56 in a gt all for 7k. if he doesnt sell it and I can come up with that money I will do the swap.
lets get this chat started.
4.10 Gear/RPM thread
Old 03-05-2014, 06:54 PM   #2
Well, I think in your case, I'd build a short block about like a Terminator. Shoot for around a 8.5-1 compression ratio and forged, of course.
Have you looked into Trick Flow heads? Pretty impressive. They seem to have taken away much of the advantage of the 4V's. Until Trick Flow starts manufacturing a 4V head that is...
As far as buying a "crate" engine vs buliding your own... that depends. Personally, I enjoy building my own engines. I know PRECISELY what parts are used and I can double check all of the tolerances myself. There's a lot of pride in turning the key and listening to the engine, that you assembled, run. Sometimes, it's just quicker and easier to have one built though.
It's going to cost a few bucks no matter how you do it...
Old 03-05-2014, 07:41 PM   #3
White03GT's Avatar
100% agree. Since you dk about a budget yet im going to throw these out there...
5.0 aluminator swap with the p1
Just do a cobra swap
Build your own 5.1 stroker with a 9-1 compression fully forged with the trick flow heads cammed.
Talk to Mzilla about his BEAST! (No ****, dude literally has a beast in his garage!)
Or go with the MMR block like you stated.
Either way you go you're looking at spending some coin man :/ and not to mention upgrading everything else for the huge power gain. (Suspension, trans, dif, etc.)
I was about to do an aluminator swap into my 03 until I bought an 04 Mach. I still sometimes catch myself day dreaming about having a wicked boosted 2v though
White03GT is offline   Reply With Quote
Old 03-05-2014, 07:46 PM   #4
2002VertGT's Avatar
Yea I know they are both going to cost...just wondering about which cost more. I would LOVE to build my own but I have never done it and would be absolutely livid if I put it all together and it f'ed up right away. I have looked at trick flow heads. If I buy a motor I'm looking at buying a long block with them. If I rebuild just looking at p&p for now. What pistons would I need to achieve 8.5-1? I saw some 23cc dishes pistons that get almost down to 9:1. How bad would low compression run n/a till I got my entire build together?
Old 03-05-2014, 07:57 PM   #5
White03GT's Avatar
I think stock compression is 9:1... Not 100% on that though...
What psi are you wanting to run? And what power are you wanting??
Old 03-05-2014, 10:53 PM   #6
Stock Termi pistons were 18 cc, but 4v heads have larger chambers, I believe. If you can get down to around 9-1, that's not bad. Anything less will either come from custom pistons or chamber work on the heads.
Lower compression N/A will give you less power. So will a set of blower cams when N/A.
It really depends how much boost you want to use which dictates the best plan for a supercharged engine build.
Old 03-05-2014, 10:57 PM   #7
2002VertGT's Avatar
I have the p1sc 3 core system...I believe it runs 10psi. On a built block is like to see 500-600 hp. The question about the low compression while n/a is incase I don't have the $ for the tune right away. It won't run long like that and I'll have my truck to drive too so it probably won't see much street and I have no plans to track it much at all let alone till I have it set up right with boost.
Old 03-05-2014, 10:58 PM   #8
2002VertGT's Avatar
My biggest ? Here is what do I need to build a motor and about how much will it cost (without labor) and someone with experience on labor charges what do you think labor would run if I had a shop do it? If it comes close to what I can buy a long block for regardless of the fact that I would love to build it I'll leave it to the pros and get a warranty.
Old 03-05-2014, 11:03 PM   #9
2002VertGT's Avatar
Completely missed your post man... 5.0 aluminator? Is that the 5.0 block you can find on AM? Pretty sure I'm gonna stroke whatever block I use. I'm just not to smart on this stuff cause I've never done it. I don't know what all I need or what it cost and I can't look it all up w:I knowing what I need. One reason I'm thinking about just having mmr build me a motor with all the bells and whistles (like the 750 or 900 block) and calling it a day. Other issue is I really don't have a garage yet, wife may be upset if I sell the table and build a motor in the dining room.
Old 03-06-2014, 05:34 AM   #10
White03GT's Avatar
If you want 5-600 rwhp on 10# you're going to want about a 10.5:1 cr. That would be decent NA as well.
Old 03-06-2014, 05:35 AM   #11
White03GT's Avatar
Yes thats the one lol. I always heard it better to ask for forgiveness then permission ha
Old 03-06-2014, 11:26 AM   #12
If I was going to build a N/A street engine, I'd be trying to get around a 10.5-1 compression ratio.
10.5 is way too high for supercharging. Period.
Especially, with fuel injection. Carburetors? Maybe, but you're still going to be stuck using high octane fuel, low boost, not much timing.
Anything over 9.5 becomes a tuning nightmare. Around 9 is a good compromise. Ford made the Terminators 8.5 for a reason.
A perfect example of this is the "Pinging Knocking" thread in this forum...
Old 03-06-2014, 11:38 AM   #13
Rapinator126's Avatar
10.5 is fine for supercharging or any FI you will just have to run e85.
Old 03-06-2014, 11:46 AM   #14
White03GT's Avatar
Good luck getting 500-600 whp at anything less then that on only 10 psi. I know plenty of people that have 10.5:1 or higher with fi set ups no problem.
Old 03-06-2014, 12:09 PM   #15
Of course it can be done. But why limit yourself to those power levels? If you're going to build an engine, why not one that could go to 7, 8 900 horsepower?
As for the E85, yes, that is what you need to pull it off. There's a better quench with alcohol to cool down the charge, which is the problem with using high compression and supercharging.
I know what the guys on these forums have to say about this. Why don't you guys look into what the engine builders are doing? Or the supercharger manufacturer's themselves.
Procharger, for instance...
Old 03-06-2014, 12:38 PM   #16
I am doing it. Made 700 the first time with 11.5 on e85 and nitrous. New set up with new motor is still 11.5 and going turbo with e85. So I have dobe it and know it can be done.
Old 03-06-2014, 12:40 PM   #17
White03GT's Avatar
OP said he was looking for 5-600 whp at 10#s. Hence the reason i said 10.5:1 cr. Of coarse you can get loads more safely with higher boost and lower cr.
Old 03-06-2014, 12:57 PM   #18
I don't see anything wrong with the nitrous.
It will be interesting to see how that works for you with boost...
Id invest in meth injection for that setup.
Engines are a completely different animal on alcohol. I used to have a neighbor who was a well known sprint car racer here on the west coast. He had an 18-1 compression, N/A, 410 cubic inch small block Chevy that ran on Methanol... 900+ horsepower. Again, normally aspirated.
Old 03-06-2014, 01:01 PM   #19
Bud you cant run meth and e85. So u need to look more info something b4 you give advice. My motor is built for it. Far from stock 2012 gt.
Old 03-06-2014, 01:08 PM   #20
Gee Whiz... I guess your right.
Real happy about your engine Rapinator...
Old 03-06-2014, 01:11 PM   #21
Just saying meth and e85 do not mix. Its been tried b4 no gains at all. Meth is a bandaid for pumpgas. I ran meth on my 03 cobra more of pain in the *** then anything. The nozzles l'île to fail on occasion. If your tune relys on it and the nozzle rails. Then it may be bad.
Old 03-06-2014, 01:23 PM   #22
Naw, I hear you man. It would have to be a "max effort" engine to make use of both.
Like I said, it will be interesting to see how much boost that you can put to your high compression engine running on E85.
The biggest problem, for me, would be the availability of the E85. No place sells it where I live right now and, from what I've seen, the stations that sell it are far and few between, here in CA.
Old 03-06-2014, 01:30 PM   #23
We will go to 17 psi.
Old 03-06-2014, 01:50 PM   #24
2002VertGT's Avatar
5-600 is a starting target. I know bigger is possible. I'm not building a track monster to stand on it's ***. I want more power to have fun with. My car is a convertible not looking to twist it into a mangled mess. If I need a smaller pulley to produce more boost I can do that. What can the stock 3650 handle? What about the t56?
Old 03-06-2014, 04:06 PM   #25
The 3650 can handle 360 ft-lbs of torque. The T-56 around 700 ft-lbs.
Keep in mind, those numbers are for warranty purposes, and, usually, both transmissions can handle substantially more power than that.
Of the many factors that determine drivetrain longevity, having a too aggressive clutch is probably the most destructive.
Old 03-07-2014, 04:52 AM   #26
2002VertGT's Avatar
Have a bad left hip...not planning on aggressive clutch. Actually thinking about spending the coin for a hydraulic setup at some point...just don't feel like ever giving up the man pedal.
Questions for the newer 6ers... V6 stang 2005-2010 V6 Mustang 42 09-23-2016 05:03 PM
13-14 Shaker 500 questions. Capn__Morgan Mustang Audio & Video 7 02-06-2014 01:34 PM
Procharger questions FordLife93 2005-2010 Mustang GT 2 06-28-2013 09:06 AM
NOTICE! Do Not Post Questions About Your Car Here Trojan Horse ME Site Help & Announcements 0 08-15-2012 02:20 PM
95 GT questions deadsp0t 1979-1995 Mustang GT 54 11-04-2011 02:16 PM
03:57 PM
