Hesitation problem, need help - Mustang Evolution
Old 03-05-2014, 06:01 PM   #1
Screaming Mach's Avatar
Ok I notice when I get on it in second gear that I'm getting a hesitation instead of consistent power thru the rpms and then a burning smell (not the tires) lol I don't know what is causing it, any help? Thanks
---------- Post added at 07:01 PM ---------- Previous post was at 07:01 PM ----------
And I have a 5 speed
Screaming Mach is offline   Reply With Quote
Old 03-05-2014, 06:57 PM   #2
Does it smell like clutch?
Old 03-05-2014, 07:04 PM   #3
No it doesn't. I'm thinking it's the catalytic converters! But would that have anything to do with the hesitation?
Old 03-05-2014, 07:07 PM   #4
White03GT's Avatar
Could. Is it missing? Have you pulled your plugs and checked them?
White03GT is offline   Reply With Quote
Old 03-05-2014, 07:07 PM   #5
They would for sure!
Are there any codes?
Old 03-05-2014, 07:09 PM   #6
Clean98 Gt's Avatar
Check your coil packs and wires. Is it only happing in second???
Clean98 Gt is offline   Reply With Quote
Old 03-05-2014, 07:12 PM   #7
No codes yet!
Old 03-05-2014, 07:16 PM   #8
Is it a unburnt fuel smell? Or a sulphur smell?
Old 03-05-2014, 07:19 PM   #9
I have replaced 6 coils so far and every time one has went bad it thru a code but no code yet! And no it's when I get on it and try pulling Thru the gears as it get's higher in the rpms is when it gets worse!
Old 03-05-2014, 07:21 PM   #10
Sulphur smell
Old 03-05-2014, 07:29 PM   #11
Ok I was getting on it again and it did the same thing, so i pulled over got out and could smell it, and now sounds like a exhaust leak right In front of my driver side cat, so I think my catalytic converter is bad!!!
Old 03-05-2014, 07:46 PM   #12
Clean98 Gt's Avatar
It sounds like it might be your problem. Ive heard of the it smelling when its bad and it gets clogged up as well so the air flow is little. Hopefully thats it. Good luck.
Old 03-05-2014, 07:47 PM   #13
I hope it is and thanks man
Old 03-05-2014, 07:48 PM   #14
White03GT's Avatar
Sulphur smell
Cats
Old 03-05-2014, 07:51 PM   #15
Thanks everybody for the responses! Im just going to get rid of my cats and hope that's it
---------- Post added at 08:51 PM ---------- Previous post was at 08:50 PM ----------
Originally Posted by White03GT View Post
Cats
Ok thanks man.
Old 03-05-2014, 08:00 PM   #16
Mosified's Avatar
An exhaust leak before the O2's will throw off the MAF. IDK if that's a possibility but it happened to me.
Old 03-05-2014, 08:04 PM   #17
Did it throw a code when that happen to you?
Old 03-05-2014, 08:17 PM   #18
Mosified's Avatar
I didnt throw a code. I just know my car started running like crap. I installed new gaskets and it runs like new again. Night/Day difference. Bad cats smells like rotten eggs.
Old 03-05-2014, 08:18 PM   #19
Mosified's Avatar
Just think if your air/fuel ratio is slightly off, not enough to throw a code but enough to notice a difference...
Old 03-05-2014, 08:20 PM   #20
Mosified's Avatar
At least, fix your exhaust leak first and drive a while to see if the computer levels itself out.
Old 03-05-2014, 08:22 PM   #21
Mosified's Avatar
Make sure your air filters clean and make sure all your vacuum connections are tight.. Thats all simple stuff..
Old 03-05-2014, 08:25 PM   #22
Will do I will check everything tomorrow, thanks for the help
Old 03-05-2014, 08:27 PM   #23
Mosified's Avatar
Any time hope it's something simple..
Slight Hesitation @2800-3000 Aggiesrok 2005-2010 Mustang GT 11 01-31-2012 11:57 AM
Problem with OBD Code P0455 tonyjuan 1996-2004 Mustang GT 2 01-23-2012 10:28 PM
Musatng Hesitation dbroncolish 1996-2004 Mustang GT 23 09-19-2011 09:47 AM
Problem with OBD Code P0455 tonyjuan 1996-2004 Mustang GT 8 08-24-2011 09:51 PM
Please Help Transmission Problem znpzmustang Pre-2005 V6 Mustang 1 07-26-2011 12:52 PM
06:37 AM
