03 gt woes - Mustang Evolution
Old 03-08-2014, 05:06 PM   #1
03 gt woes
Recently got into mustangs...but not to automotive performance.
Recently bought an 03 gt with a leaking intake manifold...
I replaced that with a new frpp manifold.
Before the swap I had a condition where it would stumble at idle a little, then during wot pulls it would act as if it were starving for fuel.
I really figured the leak was soaking a plug or two causing a misfire. I blew the plug bores out with air when I had the Mani off and got some liquid out of a couple.
I put it all back together and everything went smoothly. I replaced the gasket on the IAC simply because the ford store didn't have a valve on the shelf.
Long story short, with the new intake and dry plugs, I've still got a stumble at idle, which according to my live wire, is around 680-710rpm.
Anyone wanna guide me to a starting point? Are these 2v coils known for breaking up?
I have several k$ worth of diagnostic tools, but I don't have an IDS, so I can view most anything, just can't flash.
Any advice is welcomed.
Thanks
Adam
sent while driving recklessly
adamv7010 is offline   Reply With Quote
Old 03-08-2014, 06:08 PM   #2
WJL
Is it just at idle, how's it run at other wise?
WJL is offline   Reply With Quote
Old 03-08-2014, 06:10 PM   #3
slow281
sixpac's Avatar
Region: Nebraska
Coils arnt really prone to going out but it's a possibility.. Maybe try some fuel injector cleaner or seafome.. Did you put new plugs? And are your boots to the coils in goo shape?
Need more Horsepower? Add a sticker. Contact me for vinyl stickers pre-made and custom!
Stick on Horsepower <- Click Here and like my Page!
2001 GT - True Blue
2003 V6 - Zinc Yellow
1990 LX 2.3 - project
sixpac is offline   Reply With Quote
Old 03-08-2014, 06:27 PM   #4
Like i said in my op, it isnt 100% correct at any rpm...it acts starved for fuel during wot runs and kinda stumbles for a second then picks back up.
Plugs are new. Like I said in my op, I had an intake leak and saturated a couple boots so I won't say they're 100%
None of them looked cracked or split.
Old 03-08-2014, 07:47 PM   #5
Roguestang's Avatar
The cops can crack and the boots can rot out over time, but you would notice that if you pulled them out. Did you clean the IAC while it was off the car? If not I would try that. And the MAF just incase.
Just thinking outloud here, but did you ever disconnect the battery and see if the ecu can relearn the curve?
1990 Mustang GT w/ Vortech V3
***resident gun idiot***
Old 03-08-2014, 07:57 PM   #6
I cleaned the IAC and put a new gasket on...only reason I didn't replace it was because noone has one on the shelf here but ford had gaskets so I just threw a new on one.
I did not clean the maf. And that brings a new thought to mind.. the car has a cheap *** cai on it where the filter is still under the hood in the bay and not in the fender. The op put that on. I have a new better one in a box waiting to go on.
Yes the battery was out of the car for a couple days after I tore it apart while I was waiting on a replacement intake.
Old 03-08-2014, 08:16 PM   #7
Roguestang's Avatar
Well there goes those ideas...lol
Its possible the maf might be getting a disturbance of air from where the air filter sits if its close to the maf. I had that issue on my fox.
Old 03-08-2014, 08:21 PM   #8
Tomorrow I'm going to hook up my OTC tool and monitor spark on each cylinder at any given rpm and go from there. After thinking about it it could be a misfire in the upper rpm
Old 03-08-2014, 08:25 PM   #9
Roguestang's Avatar
Sounds like a plan!
Old 03-08-2014, 10:02 PM   #10
Mfore33's Avatar
Maybe bad egr valve?
Old 03-08-2014, 10:10 PM   #11
Would that cause the issues in the upper rpm range though?
Old 03-08-2014, 10:12 PM   #12
Roguestang's Avatar
No it wouldn't
Old 03-08-2014, 10:20 PM   #13
These fukers are so much harder to troubleshoot than the diesels I'm used to. Lol
With a diesel there's only about 4 possibilities to rule out before its a hard part failure.
Damn gas engines lol
Old 03-09-2014, 05:24 PM   #14
I cleaned the maf a little today. I didn't have any elec cleaner so I used a little carb cleaner and blew it out w air.
That made a good difference in the unresponsiveness. It still has a rough idle/stumble around 1k rpm while sitting still. Any ideas?
It seems to run better in normal driving and wot conditions now.
I do think the maf is seeing a bit of turbulence due to the design of the eBay cai the previous owner put on...pics attached...but that will be gone soon. I have a new better one from late model that has a bend and some straight pipe before the maf sensor.
Anyone wanna take a stab at the rough condition at and around 1k rpm?
Rail pressure is around 42psi.
Old 03-09-2014, 05:50 PM   #15
Old 03-09-2014, 06:11 PM   #16
Roguestang's Avatar
Swap the better cai on and that should make the difference
Old 03-09-2014, 06:28 PM   #17
That's what I'm thinking. It may not clean it up 100% but it'll make a good difference I think.
It should lessen the velocity the maf sees.
There's a reason ebay mess is cheaper
Old 03-10-2014, 08:55 AM   #18
try replacing the IAC valve? also, what about your TPS (Throttle Position Sensor)
and you should be getting codes... dont understand what you meant by having diagnostic tools/not being able to flash??
if cannot read codes, possibly look at/swap around plugs (checked gaps??!) and cop's. and what about fuel injectors? check connections on those.
good luck. let us know what you find-
Mach1Now is offline   Reply With Quote
Old 03-10-2014, 08:59 AM   #19
oh... one more thing! my favorite fuel additive- Lucas Upper Cylinder Lubricant
Old 03-10-2014, 01:57 PM   #20
Injector & cop connections are good.
I have pretty extensive diagnostic software, buy don't have fords factory software, IDS. Which would allow reflashing the ecm to stock parameters, which would clear any inconsistencies from prior tuning etc etc. I do have GM's tech software which allows reflashing ecm and TCM components.
I haven't replaced the IAC, would that cause issues above idle rpms?
Tps is within OEM spec
Old 03-10-2014, 02:55 PM   #21
Roguestang's Avatar
An iac could cause it to stumble on acceleration if the valve gets hung up (from carbon build up) or stuck open or closed. But usually cleaning it out will fix the issue (maybe temporarily) unless its an electrical, or mechanical issue.
Old 03-10-2014, 03:34 PM   #22
That's what I was thinking as well. Like I said earlier in the thread , I cleaned it good with brake & carb cleaner about 10 miles before I replaced the intake and that temporarily fixed the rpm hanging for the most part.
I'll replace it in a couple days when I get home before midnight. Lol.
I haven't decided what exactly I'm going to do with the car, so I'm not sure how deep I want to get into it. It will likely be painted & sold after I get it running right. But who knows...it only has 115k miles and a near perfect interior so there's a lot of value left in her.
Old 03-10-2014, 05:18 PM   #23
Roguestang's Avatar
Yeah sounds like a nice car. Got some pics other than of the ghetto cai? Lol
Old 03-10-2014, 05:35 PM   #24
ID:	150247Click image for larger version
ID:	150248Click image for larger version
ID:	150249Click image for larger version
Last is dirtyyyyy lol
Old 03-10-2014, 05:54 PM   #25
Roguestang's Avatar
Looks good! I could actually see a two tone paint job with the top half beimg silver on the blue. It could get alittle lower, but its a nice clean car none the less
---------- Post added at 06:54 PM ---------- Previous post was at 06:54 PM ----------
Oh and a Mach 1 grill delete lol
Old 03-10-2014, 06:44 PM   #26
I actually thought of doing the hood trunk and top a bright silver over the blue...but it would probably limit my potential buyer pool
Old 03-10-2014, 07:00 PM   #27
Originally Posted by adamv7010 View Post
Attachment 150247Attachment 150248Attachment 150249Attachment 150250
What the..
THATS WHERE MY HOOD WENT!
Thief lol
Sent from my Barbie Dream Phone®
CoolHorsey is offline   Reply With Quote
Old 03-10-2014, 07:40 PM   #28
Originally Posted by CoolHorsey View Post
What the..
Thief lol
Lol the previous owner did that so I can't say for sure if it is or not Lol
Where you located?
VIDEO: 617HP Supercharged Mustang GT Tears Up Our Dyno! AMDanBailer AmericanMuscle 8 02-24-2014 03:19 PM
Dropping in a 2000 gt motor Blackedout Pre-2005 V6 Mustang 20 02-07-2012 09:48 PM
2005 Mustang GT 350 Tribute Car (Mineral Grey Lovers) 2K05GT Pictures and Videos 8 02-01-2012 04:43 AM
1966 Ford Mustang GT Fastback Raffle to Protect Children jdipietro ME Site Help & Announcements 1 07-01-2011 04:43 PM
07:36 AM
