Clutch pedal vibration - Mustang Evolution
Old 03-11-2014, 12:23 AM   #1
03stanglife's Avatar
Hi there, I'm new to this site and just had a question...I recently replaced the clutch on my 03 mustang gt and when I got done I took it for a test drive and noticed that when I would put my foot on the clutch pedal I could feel it vibrating. I can feel it in every gear as I'm driving but as soon as I depress the clutch it goes away.I'm curious as to if this is because there is too much slack in the cable or if maybe one of the fingers is bent on the pressure plate or something else! I would love to hear any input you guys have! Thanks
03stanglife is offline   Reply With Quote
Old 03-11-2014, 07:48 AM   #2
Stock or aftermarket quadrant
Old 03-11-2014, 08:59 AM   #3
I've still got the stock one.
Old 03-11-2014, 09:25 AM   #4
Mile high JDF's Avatar
Try readjusting your quadrant, that may solve your problem. Where does the clutch catch at right now?
Sent from my DROID BIONIC using Mustang Evolution mobile app
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 03-11-2014, 09:37 AM   #5
^^agreed try adjusting the stock quadrant and see if that helps. I've read lots of pays on various sites about clutch issues with a stock quadrant that were fixed by simply adjusting it, Google it for instructions if you don't know how but it's pretty easy just pull up as hard as you can till you hear a pop, then press the pedal back down
Old 03-11-2014, 01:17 PM   #6
Ok thanks I'll try doing that! It catches near the top of the pedal.
Old 03-11-2014, 04:00 PM   #7
Thunderupokc81's Avatar
It's normal
Thunderupokc81 is offline   Reply With Quote
Clutch Pedal Height Adjustment and Clutch Freeplay Mod ab_mach1 1996-2004 Mustang GT 126 10-20-2017 03:21 AM
Check engine soon light came on? KamzGT Pre-2005 V6 Mustang 27 09-14-2013 04:33 PM
Transmission fluid for the T5 Combatman 2005-2010 V6 Mustang 18 08-05-2013 04:23 AM
If u have air in the break fluid can that make ur clutch pedal feel stiff? bluestorm52 2005-2010 Mustang GT 7 12-10-2011 04:49 PM
New clutch, too soft pedal FerKnight 2005-2010 V6 Mustang 2 08-29-2011 11:37 AM
05:51 PM
