Operation heart swap begins - Mustang Evolution
Old 03-11-2014, 07:08 AM   #1
2002VertGT's Avatar
Believe I spun a bearing, swapping a used motor in so I can rebuild my current motor Click image for larger version
Name:	ImageUploadedByMustang Evolution1394543140.640234.jpg
ID:	150297Click image for larger version
Name:	ImageUploadedByMustang Evolution1394543319.586972.jpg
4.10 Gear/RPM thread
Old 03-11-2014, 07:44 AM   #2
Roguestang's Avatar
Good luck with the swap and build! I lol'ed at your crown cover for I assume your license plate
1990 Mustang GT w/ Vortech V3
***resident gun idiot***
Old 03-11-2014, 07:57 AM   #3
What are your plans?
Sent from my Barbie Dream Phone®
CoolHorsey is offline   Reply With Quote
Old 03-11-2014, 09:23 AM   #4
2002VertGT's Avatar
lol yeah starter is giving us greef
Old 03-11-2014, 09:24 AM   #5
2002VertGT's Avatar
Name:	ImageUploadedByMustang Evolution1394551445.264924.jpg
Old 03-11-2014, 09:25 AM   #6
2002VertGT's Avatar
Plans for now is the get this motor out and get the other one and so I can drive it
---------- Post added at 10:25 AM ---------- Previous post was at 10:24 AM ----------
I have another thread going as he questions about a build I'm not sure if I want to rebuild this one or just buy a motor from MMR or something like that. But I do have a pro charger P-1 SC to go on it afterwards
Old 03-11-2014, 09:27 AM   #7
mystang50's Avatar
sub'd
good luck
Old 03-11-2014, 10:03 AM   #8
2002VertGT's Avatar
Anyone know how to get to the top transmission bolts?
Old 03-11-2014, 10:43 AM   #9
Very carefully. No easy way.
Sent from my massive johnson.
Old 03-11-2014, 01:53 PM   #10
After removing the drive shaft and cross member very carefully Jack up the front of the engine a little it can give you like an extra inch of clearance and use probably like 3ft of extensions maybe a swivel
Old 03-11-2014, 01:57 PM   #11
2002VertGT's Avatar
Just removed the whole tranny...Click image for larger version
Name:	ImageUploadedByMustang Evolution1394567826.204525.jpg
ID:	150331 that was after we took it out and then took bolts out
Old 03-11-2014, 01:59 PM   #12
Nice that's one way to do it
Old 03-11-2014, 02:21 PM   #13
2002VertGT's Avatar
On my way to get clutch alignment tool. Some stuff we have to swap over
Old 03-11-2014, 04:05 PM   #14
2002VertGT's Avatar
Name:	ImageUploadedByMustang Evolution1394575492.663757.jpg
ID:	150346Click image for larger version
Name:	ImageUploadedByMustang Evolution1394575528.318078.jpg
ID:	150347gettin ready for install
Old 03-11-2014, 07:27 PM   #15
2002VertGT's Avatar
She's in, gotta button everything up and double check everything tomorrow....Click image for larger version
Name:	ImageUploadedByMustang Evolution1394587648.915847.jpg
Old 03-11-2014, 07:40 PM   #16
Roguestang's Avatar
Sweet! I may have to have you come over and do my new edge next!
Old 03-11-2014, 08:09 PM   #17
2002VertGT's Avatar
Ugh...you'd be better off paying a shop to do it. Lol...or the non monetary payment better be huge
Old 03-11-2014, 08:32 PM   #18
Roguestang's Avatar
Lmao I've pulled many a 4.6 (with longtubes I may add) out, so I know what you mean. But I do have a fridge stocked with beer! Oh and the weather in Fl is perfect this time of year.....
Old 03-12-2014, 12:09 AM   #19
2002VertGT's Avatar
Don't like beer...got a hot sister?
Old 03-12-2014, 05:48 AM   #20
2002VertGT's Avatar
Waiting on my dad to swoop me then going back to start round two. Connection of everything and fluids and she should be ready to roll. Only thing connected on her is the trans brace.
Old 03-12-2014, 01:04 PM   #21
Roguestang's Avatar
Haha I was a single child, so no go there....lol but my fiancee does have some hot friends.
Old 03-12-2014, 03:51 PM   #22
2002VertGT's Avatar
Motors in and the car runs good but it won't move anywhere for some reason the clutch is not working
Old 03-12-2014, 03:57 PM   #23
Roguestang's Avatar
Do you have pressure in the clutch? Did you forget to but the c-clip back on the clutch fork? You sure the clutch is lined up properly? Did you torque it to spec? Will it go into gear?
Old 03-12-2014, 04:30 PM   #24
2002VertGT's Avatar
Clutch has pressure, feels like too much...it snaps back instead of letting out smooth. the c clip is on there. im gonna say its not engaging because it will not move and there is no noise. used the clutch alignment tool to align the clutch and they mated to each other quite easily so im pretty sure the clutch is aligned. it will go into gear normally. flywheel bolts torqued to 80 pressure plate torqued to 20
Old 03-12-2014, 04:42 PM   #25
Roguestang's Avatar
So you've got pressure, the pedal works, and the car will go into gear, but it Just revs and doesn't go anywhere?
Old 03-12-2014, 04:55 PM   #26
2002VertGT's Avatar
correct...the pressure in the pedal does not feel normal. it kinda snaps back instead of constant smooth pressure all the way back
Old 03-12-2014, 05:21 PM   #27
Roguestang's Avatar
Sounds like the clutch fork isn't engaging the pressure plate. Try to look where the fork come out of the bellhousing and see if anything looks good. You may have to pull the tranny off again
Old 03-12-2014, 05:35 PM   #28
2002VertGT's Avatar
could it be since its a different motor that i need to adjust? everything looks good to my knowledge...
Old 03-12-2014, 05:36 PM   #29
Is it a stock quadrant
Old 03-12-2014, 05:38 PM   #30
2002VertGT's Avatar
can the clutch disk be put on backwards? does it matter?
Old 03-12-2014, 05:41 PM   #31
Yes it matters and yes it can, disc should be labeled
Old 03-12-2014, 05:48 PM   #32
2002VertGT's Avatar
yes
---------- Post added at 07:48 PM ---------- Previous post was at 07:47 PM ----------
my dad installed the clutch, he says hes pretty sure it was put on right
Old 03-12-2014, 05:49 PM   #33
Roguestang's Avatar
+1
I know you don't want to hear it, but pull the trannu out again and re-check it.
Old 03-12-2014, 05:50 PM   #34
2002VertGT's Avatar
+1
gonna have to replace the exhaust system then....i installed a crappy one and had a lot of it welded because it was so crappy and had leaks. can the tranny be removed without removing the midpipe? its not long tubes stock headers and a mac prochamber. gonna hate getting to those top trans bolts and connectors...
Old 03-12-2014, 05:58 PM   #35
Roguestang's Avatar
That sucks. Unfortunately your gonna have to remove the exhaust too. No way around it, unless you pull the engine and tranny out together through the engine bay.
2011 3.7L V6 6R80 to MT-82 swap completed 3.7Cyclone 2011-2014 V6 Mustang 17 12-24-2014 12:00 AM
Drum to disk swap Foxresto 1979-1995 Mustang GT 12 03-10-2014 09:33 PM
4 Banger 351w Swap zhill29 1979-1995 Mustang GT 7 01-20-2014 10:22 PM
Mark viii swap? matthewhst11 Pre-2005 V6 Mustang 24 06-15-2013 09:12 AM
Motor swap Wmcgrattan General Car Discussion 35 12-05-2012 04:36 AM
06:56 PM
