Transmission bolts - Mustang Evolution
Old 03-11-2014, 10:06 AM   #1
2002VertGT's Avatar
Transmission bolts
Anyone able to tell me how to reach the top two tranny bolts?
4.10 Gear/RPM thread
Old 03-11-2014, 11:55 AM   #2
its a total pain to get up there... when i did mine though i just jacked up the car as much as possible basically and then i put a block on my jack and jacked up the oil pan just a little to tilt everything back, didnt hurt anything and it gave me some more room to get to the top two. i used a 1/2 drive rachet, a swivel and a lot of extensions... spray those bolts with some pb blaster or something too
2004 gt coupe. jba shorties, magnaflow xpipe, magnapacks, 3:73's, JLT cai, trickflow plenum, bbk tb, steeda underdrive pullies, exedy stage 2 clutch, h&r race springs, MM lca's tokico blues, pro 5.0 shifter, cobra brakes, diablo sport tune, misc cosmetics.
brandon151 is offline   Reply With Quote
Old 03-11-2014, 01:17 PM   #3
Mile high JDF's Avatar
I did most of what he said mi us the jacking on the engine part. Swivels and extensions were all I used
Sent from my DROID BIONIC using Mustang Evolution mobile app
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 03-11-2014, 01:48 PM   #4
Yeah what others have said. I carefully jacked up the front of the engine after removing the drive shaft and crossmember. It can give you the extra inch or so you need. Biggest pain personally is when putting them back in and getting torqued to spec which is like 80ftlb I think. You got so many extensions and at least one swivel... It's a pain
Old 03-11-2014, 02:18 PM   #5
if its the first time the transmission is being pulled out its gonna be a pain to actually get the tranny to slide out. when i did mine i carefully had to pry on the bellhousing a motor for the input shaft to release from the pilot bearing, so just be patient with it. i did mine without a tranny jack because im stubborn but seriously go rent one from whatever parts store is close to you, makes putting it back in so much easier
Old 03-11-2014, 04:36 PM   #6
Slow4V's Avatar
All you need is a wrench.. That's what I did
Old 03-12-2014, 12:15 AM   #7
2002VertGT's Avatar
Thanks, we ended up pulling the whole setup...was much easier
2011 3.7L V6 6R80 to MT-82 swap completed 3.7Cyclone 2011-2014 V6 Mustang 17 12-24-2014 12:00 AM
Check engine soon light came on? KamzGT Pre-2005 V6 Mustang 27 09-14-2013 04:33 PM
87 AOD rebuild bcosta56 1979-1995 Mustang GT 15 03-04-2012 09:47 AM
selling a 1989 4 cylinder mustang with a 5.0 engine and transmission both working 1987mustanglx50 2.3 Mustang 0 01-25-2012 01:30 PM
Choosing a tranny? Hawk General Mustang Discussion 0 10-08-2011 07:41 PM
08:43 AM
