2002 Lowering Springs. - Mustang Evolution
Old 03-12-2014, 02:07 PM   #1
Alerotaz's Avatar
ITs me again different question..
2002 GT Mustang Convertable.
Want to simply lower the car some.
I have new shock and struts. Getting ready to replace wheel bearings, Rack& Pinion Bushings, and Lower control arm bushings. On this Gen. of Mustang will lower springs mean I have to buy other stuff to? Just want it for the stance.
Want to do the springs since I will be getting the car a front end alinement anyway.
On my 2013 I am reading I really need the whole kit to do it right.
Found some lower springs for the 2002 new on EBAY for like 70$ It's not going to be raced, but dont want ot have to buy tires due to wear every year.
ID:	150459   Click image for larger version
Alerotaz is offline   Reply With Quote
Old 03-12-2014, 02:27 PM   #2
Mile high JDF's Avatar
How low do you plan on going? Shocks and struts are recommended with anything more than 1.5" usually, I never replaced mine when I lowered it and the car rode fine. If you plan on going any lower than 1.5" then caster/camber plates are needed, above that and you can get away with camber bolts usually
Sent from my DROID BIONIC using Mustang Evolution mobile app
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 03-12-2014, 10:46 PM   #3
edross's Avatar
if you do it, do it right, caster camber plates will get you lined-up right.
2003 gt, sct custom tuned by VMP, k&n fipk, upr o/r x-pipe, dynomax turbo mufflers, mm c/c plates, mm full length subframe connectors, h&r race springs, bullit rims 18x10 rear 18x9 front, 4.10 gears, 20% tint, 9 inch shorty antenna
edross is offline   Reply With Quote
Old 03-13-2014, 03:58 AM   #4
2002VertGT's Avatar
X10000 and get good springs...you can find sport lines cheap enough
4.10 Gear/RPM thread
Questions about lowering springs. FastFord13 General Mustang Discussion 39 04-19-2014 04:43 PM
Lowering Springs jjsg09 1996-2004 Mustang GT 14 02-06-2012 07:11 AM
lowering springs Cantlin01 1996-2004 Mustang GT 8 12-01-2011 03:45 PM
Lowering springs 89white GT 1979-1995 Mustang GT 13 08-31-2011 10:32 AM
Lowering springs 89white GT AmericanMuscle 1 08-30-2011 05:11 PM
08:00 PM
