compression restore - Mustang Evolution
Old 03-16-2014, 08:53 PM   #1
FullyAutomatic's Avatar
Region: Mexico
compression restore
OK Ok I know mechanic in a can is not top choice
However I have just finished watching a few youtube videos
where people have been using this compression restore in a can.
Add it to your oil and restores the compression...
they test compression before... and in one case 6 months later and
seems to work... any thoughts on this?
FullyAutomatic is offline   Reply With Quote
Old 03-20-2014, 07:51 PM   #2
MMVEC's Avatar
Depends on how much losses you're getting per cylinder...if it's a small enough percentage, then yes, the miracle syrop can work but if you've got big losses across the range, nothing in a can will fix it. Sometimes that s**t can cause more problems long term. Collect the data; compare it to the nominal values and go from there.
Hope that helps.
MMVEC is offline   Reply With Quote
Old 03-21-2014, 11:03 AM   #3
Black99Snake's Avatar
Oil bottle cap of motor oil into the spark plug hole and do the compression test again while someone bumps the key 2/3 times. That will help with a decent loss of compression. Been there done that trick. Worked for me. I've never used the stuff you asked about. I brought an average of 60psi up on all of my cylinders.
1999 Cobra black with medium parchment interiorJLT CAI, RWR motorsports tune, Pacesetter Longtubes, o/r xpipe w/cutouts, Flowmaster Super 44s, built t56, Kevlar clutch, Nitto NT05R, Ford Racing 4.10 gears, MMR 900 rotating assembly, vortech v3 si, twin aeromotive 340s, aeroquip lines, 80lbs injectors
Black99Snake is offline   Reply With Quote
Old 03-21-2014, 05:27 PM   #4
Mechanic in a can...
I always thought that job must really suck for a mechanic. I mean, they render a mechanic down into liquid form, put him into a can, and then pour him into an engine?!?!!?? It must be like a war zone inside of there for the mechanic. Stuff spinning, and moving up and down like It does... It's a wonder that any of them make it out alive!
It's not surprising that the stuff never works, you try working in those conditions and see how successful that YOU are...
Seriously though, years ago, the product was STP oil treatment. Claimed to reduce oil consumption, restore lost power, reduce noise etc.
Now don't laugh, but, I actually tried it in my engine once. I had one cylinder on a small block Chevy that was using enough oil to foul the spark plug every couple thousand miles.
I opened the can and started pouring it into the funnel, it was about the consistency of Honey and took about 2 minutes to pour a pint through the funnel.Lol.
Needless to say, nothing changed... still fouled plugs.
I wouldn't even consider using anything like it on one of these engines. All that stuff can do is just change the viscosity of the oil. As stated above, it can cause more problems than it will ever be capable of solving...
Old 03-21-2014, 06:59 PM   #5
Alerotaz's Avatar
Another ill be honest story..
Ok when I first really got into cars . I bought a 74 model El Camino that had the oil light turn on whn the car would idle (225$). I only wanted it for hauling small loads "so I thought", I can get by with just adding the thick oil. I ran straight 50 weight and that oil honey. Motor was so bad it had a hard time building up air pressure for the brakes....
Needless to say... It didn't last long! LOL
Alerotaz is offline   Reply With Quote
Compression test. 86custom 2011-2014 Mustang GT 16 01-23-2014 10:30 PM
compression question 93_347foxbody 1979-1995 Mustang GT 12 05-15-2012 06:56 AM
Found my compression issue 86TBarHatch 1979-1995 Mustang GT 2 12-24-2011 03:36 PM
restore yellow burnt headlights cheap 1988_gt_5.0 General Mustang Discussion 10 10-15-2011 04:24 AM
What compression ratio to go with 99gtstangn 1996-2004 Mustang GT 2 10-04-2011 09:53 PM
11:11 AM
