Please help - Mustang Evolution
Old 03-18-2014, 07:43 PM   #1
Doe_Rae_mi's Avatar
Please help
Hey guys I need help on my suspension. Everytime I go up a hill or a bump something on the the driver side creaks. I put brand new balljoints in about 3 weeks ago Which seemed to have fixed the noise until now. Idk what it is but it sounds horrible. Does anyway have any idea what it could be???
Old 03-18-2014, 07:49 PM   #2
jonathanadams22's Avatar
Could be the struts
jonathanadams22 is offline   Reply With Quote
Old 03-18-2014, 08:00 PM   #3
Doe_Rae_mi's Avatar
If I even close my door it'll creak lol
Old 03-18-2014, 08:01 PM   #4
I had that same problem had to replace ball joints outer tie rods rack and pinion and struts
Old 03-18-2014, 08:03 PM   #5
Doe_Rae_mi's Avatar
Wow sounds expensive
Old 03-18-2014, 08:16 PM   #6
Not to bad cost me $1000 for parts and labor
Old 03-19-2014, 07:49 AM   #7
Seegin's Avatar
I had the same problem. Turns out the intake manifold on 00-04 is infamous for leaking and radiator fluid made it's way down the drivers side and messed up the steering rack bushing.
Seegin is offline   Reply With Quote
Old 03-19-2014, 08:19 AM   #8
Doe_Rae_mi's Avatar
Idk if it's my shocks tho cause my car isn't bouncy
---------- Post added at 10:19 AM ---------- Previous post was at 10:19 AM ----------
Can't be I fixed my cracked intake over a year ago
Old 03-19-2014, 08:46 AM   #9
Seegin's Avatar
Yeah your better off just replacing the manifold
Old 03-19-2014, 08:49 AM   #10
Doe_Rae_mi's Avatar
I alrdy have? Lol. Like over a year ago. It's not cracked again
Old 03-19-2014, 09:02 AM   #11
Check the outer tie rods
TomFromMySpace is offline   Reply With Quote
Old 03-19-2014, 09:10 AM   #12
Doe_Rae_mi's Avatar
Lol I'm trying to take that seriously
Old 03-19-2014, 12:36 PM   #13
Doe_Rae_mi's Avatar
Doesn't make the noise when I turn my stearing wheel
Old 03-19-2014, 12:42 PM   #14
Doe_Rae_mi's Avatar
Only does it when rolling slow
Old 03-19-2014, 12:56 PM   #15
EthanGT03's Avatar
Ball joints maybe? Check em see If the boot is worn out I have the same problem. If worn spray some white lithium grease in there is the noise stops you know you need to replace em
EthanGT03 is offline   Reply With Quote
Old 03-19-2014, 01:00 PM   #16
Doe_Rae_mi's Avatar
Brand new balljoints got them nt even 3 weeks ago
Old 03-19-2014, 02:23 PM   #17
Mfore33's Avatar
I had new shocks installed a year ago and started hearing a squeak when the shock on the right side would compress. The rubber bump stop was squeaking. Put a little wd40 and it stopped.
Old 03-19-2014, 03:46 PM   #18
Doe_Rae_mi's Avatar
Ima try!
07:25 AM
