acceleration - Mustang Evolution
Old 03-18-2014, 10:16 PM   #1
FullyAutomatic's Avatar
Region: Mexico
acceleration
Not sure how to describe this but when I accelerate it feels... like gritty?... its not smooth... does this make sense and can anyone tell me why? 2000 GT
FullyAutomatic is offline   Reply With Quote
Old 03-18-2014, 11:52 PM   #2
Auto or manual?
Old 03-19-2014, 11:05 AM   #3
Region: Mexico
Auto or manual?
automatic...
just feels like ahhh honestly only word I can think to describe is gritty
it goes.. just not smooth .. like can feel it threw the pedal I guess u could say in a way
Old 03-19-2014, 12:24 PM   #4
Lol.
I've never heard the word "gritty" used to describe acceleration before...
You may have started something new here, FA.
"How's your car been running lately, FA"?
"It's been running really gritty".
Haha. I kind of like it!
I MAY just start using it...
Since gritty rhymes with *****ty, we'll assume that something's wrong with your car.
Can you pin down the grittyness a little better for us? Does it seem to be a gritty hesitation with the engine? Gritty vibration? Or does it just sound gritty when you're hard on the accelerator?
Old 03-19-2014, 12:53 PM   #5
Region: Mexico
HAHAH its the best word to describe it
car used to be smooth when accelerating
now when you mash the gas its ahhhh
never mind ill never be able to explain it
would have to let you drive it to see what I mean lol
Old 03-19-2014, 01:26 PM   #6
I know, it's sometimes difficult to describe things with words.
It sounds like it's some kind of vibration. Does it seem to be coming from the engine or the transmission?
Can you only feel it through the gas pedal or does it travel through the whole car?
Does the engine seem to be running the same as before this occurred?
Does the transmission seem to be working the same as when everything felt "smooth"?
Old 03-19-2014, 01:39 PM   #7
acceleration
Is it like a rattle or a chatter kind of noise?
TomFromMySpace is offline   Reply With Quote
Old 03-19-2014, 02:21 PM   #8
Mfore33's Avatar
Could be some bad gas... Happened to me once. Could be bad coil or plugs. Vaccine leak. Those are the easy fixes. Harder could be a timing chain issue like timing guide or could be broken trans or motor mount. Does it idle fine. How about vibration when you rev motor in park. I had a motor mount go bad and the engine would make whole car shake at rev and idle in park.
Old 03-19-2014, 02:55 PM   #9
Region: Mexico
I guess I feel it in the pedal... it seems to be coming from the engine.. throttle, pedal .. something like that.. like sand HAHAH omg I am reading what I am writing and this makes no sense I am at a loss for words
Old 03-19-2014, 03:21 PM   #10
Ish416's Avatar
Is it some type of hesitation? A noise? Dirty throttle cable? You drunk or drugs? A vibration?
Does it do it when in park or neutral? Only in gear?
Old 03-19-2014, 03:28 PM   #11
Region: Mexico
its like the engine is dry and has sand in it haha gritty but oil pressure is good. no knocks or ticks.. well tick but been like that for a long time...its not crazy bad but it used to accelerate very smoothly
and currently sober however that statement is not always valid
Old 03-19-2014, 03:35 PM   #12
Does it do it when the car shifts gears (into a lower RPM) than you press the gas and it hesitates and makes that noise and picks back up?
Old 03-19-2014, 03:40 PM   #13
V6 stang's Avatar
Sand in the engine... Hmm lol
2012 Mustang GT Convertible
Roush Exhaust
2003 Mustang GT (Sold)
Old 03-19-2014, 03:44 PM   #14
Region: Mexico
mmm I only truly notice it when I try and accelerate quickly... driving slow I don't notice much... its when I take off and stay on it.. just I want to say grinding but its not like gears grinding its like gritty.. its not sand but its like say a pedal bike that's fulla dirt in the sprockets and when u pedal its all gritty like compared to clean and oiled.. woooow I suck at explaining this hahahhahha yes my car has oil.. just changed it a few days ago to see if it would make a difference
Old 03-19-2014, 03:58 PM   #15
Exhaust leak maybe?
Old 03-19-2014, 04:11 PM   #16
Mfore33's Avatar
Gritty sound like the sand in an etch a sketch? Could be low octane gas that would cause pinging under heavy load at higher rpm. Fill tank with 93 for a few tanks and a bottle of fuel system cleaner.
---------- Post added at 05:11 PM ---------- Previous post was at 05:11 PM ----------
These engines like 93 that's all I use.
Old 03-19-2014, 04:17 PM   #17
Exhaust leak maybe?
Old 03-19-2014, 04:36 PM   #18
Region: Mexico
^ heh just did that couple days ago... decided to put premium gas in with a bottle of lucas gas treatment/fuel injector cleaner to see if that helps at all.. still same issue
Old 03-19-2014, 04:39 PM   #19
Mfore33's Avatar
Buy a cheap coil from jegs for 17 bucks. Use it to change one coil at a time and see if you find a flaky coil. I have one in my trunk as a emergency spare.
Old 03-19-2014, 04:59 PM   #20
Region: Mexico
hmmm u think it could be a coil?
is there a way to test it without swapping it?
Old 03-19-2014, 05:19 PM   #21
It could be and yes, you can test it. If you search cliffyk's posts, the procedure is there.
Have you noticed any loss of power since this started happening?
It DOES kind of sound like a broken motor OR transmission mount.
In any case, find a friend to sit in the car and hold the brake and step on the accelerator to load everything up like you are accelerating very hard, while you watch the engine to see if it rolls excessively to the side. Its a good idea to block the front wheels during this procedure. Also, look and listen for anything else that seems abnormal.
Anything GRITTY!
Old 03-19-2014, 08:47 PM   #22
Region: Mexico
brake and accelerate... seems like my buddy's going to do a burnout then rite threw my garage HAHAH... okay I will look into the cops more. maybe just replace them.. new parts never hurt.
ughmmm yes I notice loss of power! wouldn't say a lot but I have ocd I think when it comes to this car ..
Could be that I have been driving my girlfriends car off and on and its so smooth and gets up and goes a lot nicer then my mustang lol
Old 03-20-2014, 09:48 AM   #23
Rockauto sells just the boot and spring kit for about $2 instead of $40+ each for the coils.
I understand that the coils themselves rarely go bad, its the insulator and spring that fail, mostly.
Old 03-20-2014, 10:34 AM   #24
Region: Mexico
oh... well I have like 6 boots and springs brand new and two spark plugs..
the boots should all be new I guess I could pull them and see how they look?
Old 03-20-2014, 10:56 AM   #25
Two spark plugs?!??
Yes, change out the boots that aren't new and not sure what you have going on with the spark plugs but make sure they are reasonably fresh and have the correct gap...
Old 03-20-2014, 11:05 AM   #26
Region: Mexico
lol sorry.. I have like 6 boots and springs and 2 spark plugs alll extras in my tool box... If you guys think thats the reason for my issue I will pull the boots and plugs take a look at everything
Old 03-20-2014, 11:10 AM   #27
Unless you've done them recently, it never hurts to have a look. Just replace all of the boots while you have them out... they're cheap.
Old 03-20-2014, 12:00 PM   #28
Region: Mexico
yeah replaced the boots/springs and plugs just before winter... so should be fine but have no idea why my car feels like this... might just bite the bullet and bring it into a shop and have the mechanic take it for a quick ride. I can do the work myself most likely but need to know what work to do lol
Weird Acceleration noise of 2013 v6 Mustang!!!!!!!Please help!!!! Josephtsai 2011-2014 V6 Mustang 114 03-10-2014 01:39 PM
Unusual noise under acceleration mmike87 2011-2014 Mustang GT 2 11-05-2012 09:35 AM
hesitant acceleration Chelley Pre-2005 V6 Mustang 11 11-08-2011 12:06 PM
03 Mustang GT acceleration issue Zebs5408 1996-2004 Mustang GT 3 11-01-2011 06:02 AM
03:20 PM
