CLUTCH VIBRATING !! - Mustang Evolution
Old 03-20-2014, 10:37 AM   #1
Juh_Jayson7's Avatar
CLUTCH VIBRATING !!
I have a 98' mustang GT.. I just installed a new stock clutch and it won't stop vibrating ..? It has a small annoying noise to it aswell.. The car also vibrates when my RPM's are coming down..? Any suggestions, PLZ HELP!! ( I'm new to this... how do I send direst messages it's even possible ? )
Juh_Jayson7 is offline   Reply With Quote
Old 03-20-2014, 11:21 AM   #2
03stanglife's Avatar
Where can you feel it vibrating?
03stanglife is offline   Reply With Quote
Old 03-20-2014, 12:39 PM   #3
When you gently touch the clutch it vibrates...sometimes when Im on the road I can hear the clutch rattling.. But When I press on the clutch everything goes away?
---------- Post added at 06:39 PM ---------- Previous post was at 06:38 PM ----------
Old 03-20-2014, 08:25 PM   #4
I recently just replaced my clutch and the same thing happened to me! Supposedly it's somewhat normal. Do you have a stock or aftermarket quadrant? If you have the stock one you can try adjusting it. I did it on mine and it took most of it away. Just be sure to not adjust it too tight, you still want se play. As far as your noise goes did you torque your clutch and flywheel to specs? Maybe get underneath and make sure everything's tight and there's nothing obvious undone. Hope this helps!
Clutch Pedal Height Adjustment and Clutch Freeplay Mod ab_mach1 1996-2004 Mustang GT 126 10-20-2017 03:21 AM
For Sale: TR3650 5 Speed and Ram Dual Disk Clutch ColeJohnson Mustang Parts for Sale and Wanted 4 02-17-2014 04:20 PM
Check engine soon light came on? KamzGT Pre-2005 V6 Mustang 27 09-14-2013 04:33 PM
Transmission fluid for the T5 Combatman 2005-2010 V6 Mustang 18 08-05-2013 04:23 AM
Clutch, how can i prolong its life? the_stig 2011-2014 V6 Mustang 26 06-16-2012 07:58 PM
03:34 AM
