Need help!!! - Mustang Evolution
Old 03-21-2014, 10:28 PM   #1
saleenfan04's Avatar
Need help!!!
Hi, here the deal. My car starts up normal hot or cold no problems but right when I put in reverse rpm drops to 500 to 1000 it's keep going up and down but when I put back in park it's normal. It does the same thing when it hit around 40mph I feel like it's kind about to turn off it's kind feel like it's losing power and get back idk why any idea? Thank you
saleenfan04 is offline   Reply With Quote
Old 03-21-2014, 10:58 PM   #2
Your car is an automatic right?
It only does this in reverse? It doesn't do it in drive until you hit about 40 mph?
Old 03-21-2014, 10:59 PM   #3
Yes and both it's getting worse tho
Old 03-21-2014, 11:02 PM   #4
When you drive it does it still seem to run good and make good power?
Old 03-21-2014, 11:05 PM   #5
Yes until it's 4th gears it's got worse now it's sucks up the air and let it go shakes lot
Old 03-21-2014, 11:14 PM   #6
And it's not showing any codes. There may be some pending so I would check that. I'd also do a fuel pressure check. Also, since this blower installation is fairly recent, I'd go back through EVERYTHING that you did and make sure that all of the vacuum hoses and electrical connections are all on and tight. You may want to re-torque everything as well.
Hopefully some of the other guys will chime in with some other ideas...
Old 03-22-2014, 12:54 PM   #7
No there are no codes or anything everything is connect but I haven't got fuel pressure check which I will do Monday
Old 04-22-2014, 12:37 PM   #8
Got it fix sorry take me while to reply back. I had hole in the intake filter how I got the hole it cuz I was putting mach 1 chin spoiler and I drill a hole in the intake filler pretty stupid yes I know lol
Old 04-22-2014, 12:49 PM   #9
garbill2003's Avatar
Hey we all make mistakes glad you got it fixed
garbill2003 is offline   Reply With Quote
Old 04-22-2014, 12:51 PM   #10
Thx
---------- Post added at 10:51 AM ---------- Previous post was at 10:51 AM ----------
True, thx guys for help
Old 04-22-2014, 02:29 PM   #11
escottcarp's Avatar
At least you were doing something productive to get that hole. I don't understand why that little hole would have this particular effect, but, ok.
Just sayin'. You can put tape around the drill bit to mark the depth of a hole you want to drill.
escottcarp is offline   Reply With Quote
Old 04-22-2014, 02:42 PM   #12
Glad it was something simple!
And don't feel bad Saleen, a couple of years ago I was installing a new transmission cooler on my truck and drilled through the air conditioning condenser, losing all of the very expensive R12 refrigerant that I had been carefully saving for twenty years...
It happens!
Old 04-22-2014, 03:46 PM   #13
Omg m sorry to hear that and again no one is prefect right
Need quick help! Need to find 4.10 gears for 2010 v6 mustang?? Camaro Eater Pre-2005 V6 Mustang 2 06-08-2010 05:31 AM
Guys need help.. going to get new engine.. need advice Skyes97Stang Pre-2005 V6 Mustang 9 11-28-2009 12:35 AM
need some help from the electrically inclined (need to find a power transformer) fast64 The Bar 5 05-26-2006 03:58 PM
Need to choose new tires..need help KyleUSAF Mustang Wheels & Tires 13 11-29-2005 11:13 AM
Need Help with Viruses on my COMPUTER! HELP ASAP!! Autobadges.com The Bar 41 02-05-2004 09:53 PM
11:56 AM
