Best gears with supercharger? - Mustang Evolution
Old 03-23-2014, 12:57 AM   #1
Jgrummz's Avatar
I have an 03 GT with a vortech v2 and im thinking about getting new gears.
Which gears would be best to use with a supercharger?
Jgrummz is offline   Reply With Quote
Old 03-23-2014, 01:20 AM   #2
3.55 or 3.73
Old 03-23-2014, 01:24 AM   #3
Jgrummz's Avatar
Ok thanks.
Does it make a difference that its my DD and its mostly in town driving?
Old 03-23-2014, 01:26 AM   #4
Originally Posted by Jgrummz View Post
Ok thanks.
Both will be good. You don't want too much gear so definitely not 4.10s. If ld personally go with 3.73.
Old 03-23-2014, 01:28 AM   #5
Jgrummz's Avatar
Alright thanks i appreciate the info.
Old 03-25-2014, 05:06 PM   #6
DutchManDann's Avatar
My vote goes to 3.73s as well
Roxanne- 1998 Mustang GT Convertible: 5-Speed, 2001 PI 2V swap, o/r h-pipe, Magnaflow catback, MGW shifter,
3.73 gears, Auburn LSD, TA diff cover, MM FLSFCs, Ford Strut Tower Brace, J&M SS Brake Lines, and a lot of visual/restoration work.
DutchManDann is offline   Reply With Quote
Old 03-25-2014, 05:47 PM   #7
BigB227's Avatar
+1 to the 3.73s!
BigB227 is offline   Reply With Quote
Old 03-25-2014, 10:05 PM   #8
Slow4V's Avatar
410s ftw
Old 03-26-2014, 09:36 AM   #9
For a S trim, 4.10s or higher. For a positive displacement type set your 1st gear ratio X rear gear ratio to as close to 10 as possible and roll. For a t45/3650 car this would be a 3.08 rear gear. However you have a S trim so 4.10s.
Old 03-26-2014, 08:37 PM   #10
+1
Bigshow14 is offline   Reply With Quote
Old 03-27-2014, 10:32 AM   #11
Jgrummz's Avatar
Lol well it seems like its 50/50 between 3.73s and 4.10s. Decisions decisions i cant decide!
Old 03-27-2014, 01:58 PM   #12
4.10s, its not even a decision. More low end that these cars need and you lose like 100-200 RPM on the highway depending on how fast you go. If you've got a 02-04 (which you do) your transmission has the deep .62 overdrive gear anyway. Google "RPM calculator" and click on the first link and scroll to the bottom. Plug in the final gear ratio of your choice, tire diameter of a stock 94-04 is 25.7", 02-04 overdrive is .62 and then whatever speed you will go. 4.10s are totally fine and I have no idea why its even a debate which gear to use for a NA or S trimmed car. Hell, maybe even go 4.30s if you have a little taller tire, I'm kicking around doing 4.30s since I likely will not have the $$$ for a blower this spring/summer and I can do the gear install myself.
Old 03-27-2014, 02:08 PM   #13
I would go with 3.73s because I like the first couple gears to actually have a use. I have 3.73s on my PI swapped 98, and my first gear is pretty useless. I can't even imagine 4.10s with boost.
Personally, I feel 3.73s are the best choice. Unless you're building some purpose built race car, you want the car to be driveable.
Gears and Supercharger Question Jake 2005-2010 Mustang GT 18 09-12-2012 05:31 PM
4:10 gears vs 4:30 gears SwatKatz901 1996-2004 Mustang GT 5 03-24-2012 03:17 PM
3:55 Gears vs 3:73 gears 06Blue 2005-2010 Mustang GT 19 01-04-2012 06:57 PM
NEED HELP WITH GEARS!! Motive 4.10 gears? Cant find ford racing? Camaro Eater Pre-2005 V6 Mustang 4 06-23-2010 10:57 AM
Factory Gears Vs. Racing Gears tire Pre-2005 V6 Mustang 0 07-21-2003 04:02 AM
01:27 PM
