Spark plugs - Mustang Evolution
Old 03-23-2014, 04:32 PM   #1
saleenfan04's Avatar
Spark plugs
Hi, I was wondering if any one has 2.1 kenne bell supercharged or any other brand supercharged. The question is what kind spark plugs are you using?
saleenfan04 is offline   Reply With Quote
Old 03-23-2014, 07:28 PM   #2
Mzilla's Avatar
How much boost are you gonna be running and what compression?
Mzilla is offline   Reply With Quote
Old 03-23-2014, 08:20 PM   #3
BigB227's Avatar
I've heard of a lot of people running motor craft coppers but I can't remember the part number off hand. And people usually change them every oil change or so under boosted applications
BigB227 is offline   Reply With Quote
Old 03-23-2014, 09:00 PM   #4
9 or 9.5 psi right now m running ngk tr6 but week later I pull them out and they were burn from the tip and I was wondering what u guys running?
Old 03-24-2014, 06:45 AM   #5
Mzilla's Avatar
I have been running tr6 on 17psi at 11:1 compression no problem. If you burnt the tips off a cooper plug be thankful it was the cooper plug and not a piston. Your tune is way to lean. I hope you have a custom tune and not a crap can tune. You can also run tr6ix for longevity but only if your tune is spot on with the tr6.
Old 03-24-2014, 08:17 AM   #6
No i have dyno shop tuned for me but idk why m sitting having problem
Old 03-24-2014, 09:36 AM   #7
Mzilla's Avatar
Take a picture of the spark plug and post it. I can tell you by looking at it what's going on
Old 03-24-2014, 09:47 AM   #8
Alright I will right now m about to get pretest on the car cuz I been having lot of problem with my car I was thinking once I have supercharged I be fine but no it's up side so far
Old 03-24-2014, 11:22 AM   #9
Did they give you a dyno sheet on your car?
TomFromMySpace is offline   Reply With Quote
Old 03-24-2014, 11:38 AM   #10
Nope, so far this year becoming the worse year ever
Old 03-24-2014, 12:30 PM   #11
It might be the tune they gave your car that's making it act funny. If they dyno'd it why wouldn't they give you a sheet with the results?
Old 03-25-2014, 09:08 PM   #12
Cuz I went to worse dyno shop probably and here the spark plug
Pictures Click image for larger version
Name:	ImageUploadedByMustang Evolution1395803270.074717.jpg
The front part of the spark plug is light brown like it's burn or idk
Old 03-26-2014, 07:04 PM   #13
Mzilla's Avatar
You said you burnt the tip off your last set of plugs?? And pic of those plugs? This plug you posted looks ok what plug and what gap are you running. They actually look like they are burning little cold
Old 03-30-2014, 08:15 AM   #14
Raleigh_Slanga's Avatar
I'm not running boost but I know ford off hand recommends platinum tip by motorcraft of course but I use NGK platinum tips.
Raleigh_Slanga is offline   Reply With Quote
Old 03-30-2014, 11:46 AM   #15
Mzilla's Avatar
Does your spark plug have a washer on it?? If so it has the wrong plugs in it period. All 4.6 mustang plugs are taper seated plugs.
Old 03-31-2014, 09:11 AM   #16
I put them in so fast I honestly don't know..I did however compare them to the old plugs which looked the same..I just bought the car with a 100,000 miles on it and I doubt they had been changed before..they may be be the wrong ones but I I'll look and if they are ill change them..
Old 03-31-2014, 09:18 AM   #17
I think m running .28 gap that what the shop told me, and I will post another picture later on today.
Old 03-31-2014, 10:56 AM   #18
Mzilla's Avatar
I would recommend a set of NGK TR6 gapped at .032. The plugs do not need a .028 gap on your power or boost level. Double check the plugs though because your plugs should be taper seat
Old 03-31-2014, 11:03 AM   #19
And is there any kind test that I could on my car that will tell me gap, compress ratio, air/fuel. Etc...?
Old 04-20-2014, 01:07 PM   #20
Silver Pony's Avatar
I'm running a 2.1 Kennel Bell 9lbs of boost on a 2001. NGK TR6 gapped at .032 and having no issues.
Sent from my XT1080 using Mustang Evolution mobile app
Silver Pony is offline   Reply With Quote
Old 04-22-2014, 08:52 AM   #21
I still say this might be a troll user. If not its one of the most incompetent installs I've ever seen but then... I grabbed my popcorn and finished it a long time ago...
Yes I'm an ***.
Old 04-22-2014, 12:31 PM   #22
Can I change spark plug gap through sct tuner or Do I have to take back to dyno shop?
Old 04-22-2014, 03:06 PM   #23
You change the gap yourself with one of these Click image for larger version
wicked2v is offline   Reply With Quote
Old 04-22-2014, 03:44 PM   #24
Alright thank you
Old 04-22-2014, 08:37 PM   #25
I have one word for you just one word... plastics....
Wait no, I meant SELL
Sent from my VS980 4G using Mustang Evolution mobile app
Spark plugs and spark plug wires??? Moyhuerta 1979-1995 Mustang GT 11 12-05-2012 08:42 AM
No spark in the spark plugs 94GTpony 1979-1995 Mustang GT 7 10-30-2012 01:20 PM
E3 Spark Plugs Diamond Fire - Spark Plug gonzo56 2005-2010 V6 Mustang 6 09-28-2011 09:45 AM
Problem with gt40p spark plugs want some good spark plugs but most wont fit?? Justbust1n 1979-1995 Mustang GT 6 03-01-2011 03:20 PM
Spark Plugs Stang01 Pre-2005 V6 Mustang 19 07-18-2003 04:55 PM
» Members Mustangs
Sonya
akdoggie
Roy
blubill
Add your Mustang
08:54 AM
