Cutting springs - Mustang Evolution
Old 03-27-2014, 09:24 PM   #1
TheWitness's Avatar
Cutting springs
Hey guys, I think that me and a buddy are going to cut a coil out of my sr performance lowering springs this weekend. Are there any drawbacks to cutting a lowering spring? What should I be aware of?
TheWitness is offline   Reply With Quote
Old 03-27-2014, 09:27 PM   #2
SpeedMob's Avatar
Is it a progressive rate spring ? ( are all the coils equally spaced ?)
SpeedMob is offline   Reply With Quote
Old 03-27-2014, 09:29 PM   #3
TheWitness's Avatar
I'm not totally sure off the top of my head, I think they are tho. They are the sr performance springs that americanmuscle sells.
Old 03-27-2014, 09:40 PM   #4
Mile high JDF's Avatar
If they're linear then you should be fine
I've been rocking cut springs for the last year with no issues at all.
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 03-27-2014, 09:46 PM   #5
SpeedMob's Avatar
Assuming they are linear, how low do they already make the car and how much lower are you lookin to go
Old 03-27-2014, 09:58 PM   #6
TheWitness's Avatar
How can I tell if they are linear or not?
Old 03-27-2014, 11:19 PM   #7
I would start with a half coil or a quarter coil. A full coil will slam the **** out of the car
Old 03-27-2014, 11:25 PM   #8
Like SpeedMob said, typically, if they are linear, the coils will be spaced evenly from top to bottom. Just like the name implies, the coils on a progressive spring become progressively closer together.
Old 03-27-2014, 11:42 PM   #9
TheWitness's Avatar
If I cut let's say 3/4 of a coil off my lowering spring, how much more bouncy will my car be when I hit dips? Like on a scale from 1-10 how bouncy lol.
Old 03-28-2014, 12:27 AM   #10
Depends on your shocks and spring rate. Mine isn't terribly bouncy, it rides rough, but it doesn't have the Honda bounce
Old 03-28-2014, 12:33 AM   #11
TheWitness's Avatar
It has sr performance springs, says it has the factory spring rate. And I have the factory shocks, what are your thoughts?
Old 03-28-2014, 12:46 AM   #12
I have no clue what the SR spring rates. The factory shocks aren't gonna last forever, especially when lowered over 2". When your shocks go out then you'll get the Honda a bounce going.
Old 03-28-2014, 12:54 AM   #13
TheWitness's Avatar
I plan on going till there's only about 3/4-1inch of wheel gap, think I'll get a honda bounce or am I safe for a while?
Old 03-28-2014, 01:31 AM   #14
Lol.
U dont wanna hav no honda bounce goin on whichu whip yo witness...
Just cut the springs... I've got a set of Tokico's that I'll sell to you for cheap if you screw them up.
You have to pay the shipping though because I live in the middle of f'n nowhere...
Old 03-28-2014, 01:35 AM   #15
TheWitness's Avatar
Has anyone heard anything with the tein springs? They drop 2.5" in the front and 2.3" in the rear. And would the tein be better than cutting my own?
Old 03-28-2014, 01:39 AM   #16
Knowing absolutely nothing about the springs that you are referring to... I'm going to say yes, your chances for a decent ride are better.
Old 03-28-2014, 01:40 AM   #17
TheWitness's Avatar
How bad is the ride quality going to be if I cut 1 coil off?
Old 03-28-2014, 01:45 AM   #18
Im not sure with the SR springs. I AM sure that someone has done it though.
Maybe someone will chime in on the ride quality.
Are your springs stock JDF?
Old 03-28-2014, 06:17 AM   #19
SpeedMob's Avatar
Your ride will be nominally stiffer feeling- not bad though- by cutting a half coil you're effectively raising the spring rate by about 7-10%
Old 03-28-2014, 06:20 AM   #20
SpeedMob's Avatar
Our shop did a fox body with 3/4 coil cut on cj pony part .5 lowering springs Click image for larger version
Name:	ImageUploadedByMustang Evolution1396009189.253138.jpg
Old 03-28-2014, 10:46 AM   #21
Site Sponsor
Sponsor
AMWill's Avatar
I'm personally not one of cutting springs. However, the SR springs are a standard rate, so they should react better than a progressive for cutting.
Taking 3/4 of a coil off of the SR springs will drop you pretty low. Considering the springs already bring you down 1.5" from stock. I'd highly suggest picking up a set of aftermarket struts/shocks ASAP. As the stock dampeners will be bouncy and bottom out every time you hit a pot-hole or an abrupt impact. Which will also make them start leaking eventually.
Hope this info helps! Let me know if I can be of any further assistance!
Shane
Toll Free: 866.727.1266
Free Same-Day Shipping!
Old 03-28-2014, 11:58 AM   #22
TheWitness's Avatar
Shane
Maybe I should start off my taking 1/4 of a coil off. Do you think my factory shocks will last for a few months or are we talking a couple weeks?
Old 03-28-2014, 12:09 PM   #23
I've got a lot less than 1" of wheel gap on my car and I have no.bouncing issies, but I've also got aftermarket shocks. My factory struts weren't top bad but I only had them on for a few months.
there used to be a guy on here with the Twin springs. It dropped his car pretty good. Yes they will be better than cutting the SRs. I believe they have a fairly decent spring rate.
Yup the stock 03 Cobra springs.
Old 03-28-2014, 12:50 PM   #24
SpeedMob's Avatar
Tein is worth it and if you're there just replace struts with something decent - or go coil over - not QA1 if it's a street car though- rides on rails but feels like a dump truck
Old 03-28-2014, 12:52 PM   #25
TheWitness's Avatar
I'm looking into sr performance coilovers.
Old 03-28-2014, 12:54 PM   #26
Those are OK. What I'm doing, I'm gonna get KONI Yellows and the Maximum Motorsports has a kit to convert over to a coilover using those shocks and struts. You can pick the spring rate and everything.
Old 03-28-2014, 01:04 PM   #27
TheWitness's Avatar
Can you hit me with a link?
Old 03-28-2014, 01:33 PM   #28
Site Sponsor
Sponsor
AMWill's Avatar
It really depends on your driving style and how many pot-holes you hit. One good slam into a pot-hole can be enough to bottom out the dampeners and cause them to leak. I don't know if I'd go through the hassle of cutting a coil if you're only going to cut a 1/4 off. Either way you're on limited time with the factory struts/shocks.
Keep that in mind!
Shane
Old 03-28-2014, 01:45 PM   #29
TheWitness's Avatar
Keep that in mind!
Shane
Shane, I know Americanmuscle sells sr performance coilovers. Can you tell me if they are a good quality product for a daily driver like myself?
Old 03-28-2014, 01:54 PM   #30
All those high name coilover kits are, are this pretty much already assembled. Get some adjustable shocks and struts such as the KONIs and then you've got yourself a set up...
Coil-Over Kit with Springs, Koni Shocks, rear, 1979-04 Mustang non IRS
Mustang Coil-Over Kit with Springs, Front, Koni/Tokico/Strange/Lakewood Struts
Old 03-28-2014, 01:56 PM   #31
The SR ones are good if you are looking for just regular coilovers. They have 250lb springs all around and are adjustable for height, but not stiffness. So if you just want the look and a bit better handling then they are good..... If you want a car thats a track beast then go the route i'm going... I'll probably get around 350lb or so springs.
Old 03-28-2014, 02:03 PM   #32
TheWitness's Avatar
All I'm really looking for is a coilover that I can daily drive, lower probably 3inchs, not make a bunch of noise and not be total garbage like the raceland stories I've heard lol.
Old 03-28-2014, 02:08 PM   #33
Then don't cheap out on coilovers by going with the SR ones... there's a reason they're so cheap. A 3" drop is going to be pretty brutal on your suspension.
Old 03-28-2014, 02:17 PM   #34
TheWitness's Avatar
I was looking at some Bc racing ones, they look super nice. They're just under 1k, your thoughts?
Old 03-28-2014, 02:58 PM   #35
I just bought them yesterday Click image for larger version
Name:	ImageUploadedByMustang Evolution1396040332.278091.jpg
cutting springs? BlackSix Pre-2005 V6 Mustang 17 11-24-2008 09:50 PM
cutting springs.. x99xstangxx Pre-2005 V6 Mustang 11 11-07-2007 07:03 AM
Cutting springs or Buying Springs Exit_In_Red Pre-2005 V6 Mustang 38 01-06-2005 12:13 AM
Cutting Your Springs megax29 Pre-2005 V6 Mustang 45 10-13-2004 04:36 PM
cutting C springs ???? Zim Pre-2005 V6 Mustang 8 06-24-2004 12:59 PM
09:23 AM
