headers ! - Mustang Evolution
Old 03-27-2014, 10:37 PM   #1
headers !
what should i go with ? shorty headers or long tube headers ? for my 2000 mustang gt atick v8 .. ?
arthur9 is offline   Reply With Quote
Old 03-27-2014, 10:38 PM   #2
jonathanadams22's Avatar
Long tubes for sure you will make more power
jonathanadams22 is offline   Reply With Quote
Old 03-28-2014, 06:25 AM   #3
Shorties will make no more power over stock manifolds. Modulars are not like the previous 5.0s that had terrible factory headers. Longtubes will make a little more power but you're going to have to drop the K member to install them.
Honestly, if you have things to improve in other areas I'd do that first.
Old 03-28-2014, 09:02 AM   #4
Slow4V's Avatar
If I were you I would invest in rear gears and suspension, those will be more noticeable ..
If you just want a good exhaust tone. Just get a mid pipe and some weld in mufflers, and nice tips.
Old 03-28-2014, 09:03 AM   #5
Definitely don't neglect the tip.
Old 03-28-2014, 04:25 PM   #6
Roguestang's Avatar
Zing!
On a N/A 2v 4.6 you won't notice much of a difference with LT's. But it is definitely a supporting mod if you have an F.I. setup. Like stated earlier, I would use the money for suspension and other things first.
1990 Mustang GT w/ Vortech V3
***resident gun idiot***
Old 03-28-2014, 06:58 PM   #7
No, you will notice it but a good set like slp or kooks are going to run $800+. Often this money can be put to better use unless everything else is done.
Sent from my VS980 4G using Mustang Evolution mobile app
Old 03-28-2014, 07:10 PM   #8
Eturner's Avatar
Just had Tuned Length (Shorties) and a intake installed on my '04 GT!.. Noticed a nice gain over factory!..
Old 03-28-2014, 07:43 PM   #9
Roguestang's Avatar
I've got a set of Mac LT's and besides the sound, I didn't notice a difference with them.
Old 03-28-2014, 09:30 PM   #10
Its probably there but not enough for the SOTP-o-meter to pick up on. We're talking 10-15ft lbs at most on a NA 2V. Strokers and 4Vs will see a bit more pickup but the funny thing is with a blower you aren't worrying about the scavenging effects anymore so it makes sense to leave the shorties on if you ever plan to do a supercharger later on so you aren't running into ground clearance issues or issues pulling the trans for whatever reason.
In all honesty I don't think they are worth it unless you are a big power boosted app, nitrous or a stroker doing an max effort NA build. To each their own though. The PO of my car put FRPP shorties on this engine I'm assuming when it was out of the car (99 PI engine swapped into my 98) as that would make the most sense. Non-ceramic but stainless and they should hold up a very long time. My stainless 94/95 FRPP headers looked nearly brand new when I pulled them off after running them from 2003-2009.
Old 03-29-2014, 05:53 AM   #11
Roguestang's Avatar
Ok so we're on the same page then. I knew there was alittle gain with the LT's, but not enough to feel it. That's what I was saying in my post but not so long winded.
With the a/c drain pipe where it is, it leaks on the passenger side header and gave it an awful stain. But they have held up pretty good otherwise too. And they aren't coated either.
Old 03-29-2014, 06:36 AM   #12
Long winded?
Haruummmpphh!
Old 03-29-2014, 08:56 AM   #13
Roguestang's Avatar
Lol no offense! You do better at explaining it anyways
Old 03-29-2014, 10:28 AM   #14
Why doesn't ford racing make their own set of long tubes?
http://imageshack.com/a/img845/1663/pg2f.jpg
RyanSeacrest is offline   Reply With Quote
Headers or no headers Cobra2010 Shelby Mustang 27 09-05-2012 08:11 PM
Longtube headers or shorty headers? Stanglover1966 General Mustang Discussion 5 07-29-2012 09:10 AM
Jba 1 5/8 shorty headers (insight on jba headers) go or no go? Swangin_Stangs 1979-1995 Mustang GT 24 01-13-2012 06:15 PM
headers or no headers what do you think 02mach6stang Pre-2005 V6 Mustang 2 06-16-2008 06:11 PM
94-98 Factory headers VS 99-04 Factory headers Herbstang Pre-2005 V6 Mustang 2 08-08-2007 04:53 PM
04:26 AM
