engine problem? - Mustang Evolution
Old 03-28-2014, 05:47 AM   #1
to_oaxaca's Avatar
Region: Nevada
engine problem?
My gt has recently started to turn off at random times in the past 2 weeks. I would be around 2-3k rpms and suddenly it would just go below 1k, the steering wheel gets hard, and just shuts down.
I had a little accident about 4 weeks ago, nothing major, just went into a trucks' hitch, maybe that influences this?
Any causes??
to_oaxaca is offline   Reply With Quote
Old 03-28-2014, 10:04 AM   #2
Slow4V's Avatar
Any engine codes?
Could be a vacuum leak somewhere,
If not could be a faulty TPS sensor
You can check it for the correct volts.
Or maybe something got into your mass air flow meter , you could clean it out.
Just things like that.. Just troubleshoot different things.
Old 03-29-2014, 08:59 PM   #3
MMVEC's Avatar
Idle Air Control (IAC) comes to mind..it won't throw a code but has the symptoms...it's about $50 and takes 10min to replace.
MMVEC is offline   Reply With Quote
Old 03-29-2014, 09:08 PM   #4
SpeedMob's Avatar
Is the car c.o.p. or way-spark?
SpeedMob is offline   Reply With Quote
Old 03-29-2014, 09:10 PM   #5
to_oaxaca's Avatar
Region: Nevada
Thanks guys I'll get it checked out , other wise, i might just sell it 💔
Old 07-19-2014, 02:41 PM   #6
MMVEC's Avatar
Any updates?
Big problem-easy find, small problem-hard to find Dnraiders General Mustang Discussion 0 08-30-2011 12:10 PM
Big Problem Guys- Engine shuts down! DMAC Pre-2005 V6 Mustang 7 12-03-2007 11:29 AM
Engine problem, need expert input here! ASSEMbler Pre-2005 V6 Mustang 28 01-25-2004 12:42 PM
News update on engine problem Danger Dude Pre-2005 V6 Mustang 14 08-11-2003 02:54 PM
07:15 AM
