Race tune problems P0781 - Mustang Evolution
Old 03-29-2014, 02:39 PM   #1
Tangtang2.0's Avatar
So when I got my 00 gt the old owner gave me the tuner with it and I never bothered to use it because when I tuned the car it shifted weird and a code always popped up so I always kept it stock.. So recently I tried updating the tuner but it got locked so I had reset lost the old tunes. So I contacted AM and they sent me the old tunes after I fixed the tuner with sct. So after tuning my car a couple days went by and the the o/d light started flashing and it gave me this code P0781. Do you guys have any idea what could be happening?
Tangtang2.0 is offline   Reply With Quote
Old 03-31-2014, 02:38 PM   #2
Anyone?
Old 04-01-2014, 07:30 AM   #3
V6 stang's Avatar
Have you googled the code yet to know what it is?
2012 Mustang GT Convertible
Roush Exhaust
2003 Mustang GT (Sold)
Old 04-01-2014, 02:53 PM   #4
1lowGT's Avatar
1-2 shift malfunction in auto
---------- Post added at 03:53 PM ---------- Previous post was at 03:52 PM ----------
Call bama directly. It'll be much faster and educated than waiting for help here.
Old 04-01-2014, 09:09 PM   #5
Shift weird like too soon, erratic shifting ? Kinda explain it to me a little more details I may be able to help
southernstang00 is offline   Reply With Quote
Old 04-01-2014, 09:11 PM   #6
Sounds like the shift pressure in the tune is either too high or low. Does it go into gear hard ?
Old 04-01-2014, 11:50 PM   #7
1lowGT's Avatar
Did you mess with shifting on your tuner?
---------- Post added at 12:50 AM ---------- Previous post was at 12:49 AM ----------
+1 but I don't see that throwing a code. Who know tho lol
Old 04-02-2014, 05:00 AM   #8
When I first got my tuner I was messing with things and I adjusted the pressure to make it shift harder. Well I guess I got the pressure too high and it keep throwing a code, now which one I can't remember. So once I adjusted it down some it went away. Another thing it might not be related to the tuner itself. About a year later I got a coupe trans codes and then it started acting up.
Old 04-02-2014, 06:51 AM   #9
Don't f**k with the line pressure. J-mod the trans and you won't need to do that and you'll also have a longer living trans even then a stocker. Look up "j-mod tccoa" on youtube for what I am talking about. Its not as scary as it looks. If you can change your oil and are not an idiot you can do the J-mod.
Old 04-02-2014, 07:34 AM   #10
The car picks up speed faster compared to it when it's in stock, and it also seems to get to higher rpms than usual before changing into second
Old 04-02-2014, 07:56 AM   #11
If this is when the tune is on the car then what your seeing is the shift points have been adjusted to shift higher then stock. But that still shouldn't give you a code. So if there a code only when you place the tune on the car ?
Old 04-02-2014, 08:06 AM   #12
Yup .. If I return it to stock the code goes away and doesn't appear
Old 04-02-2014, 08:12 AM   #13
That's got to be a software issue with the tuner.
Old 04-02-2014, 08:16 AM   #14
What I would do is call sct directly and tell them it's throwing the code after the tuner is installed on the car but goes away when it's back to stock and see what they say.
Old 04-02-2014, 08:20 AM   #15
I did they said too update the tuner and I did And it still happens
Old 04-02-2014, 08:24 AM   #16
Hmmm Does it shift hard when the tuner is on ?
Old 04-02-2014, 08:31 AM   #17
This is a problem with the bama tune pure and simple. If they can't fix it demand a refund.
Old 04-02-2014, 08:33 AM   #18
+1
Old 04-06-2014, 08:16 PM   #19
Could it also be the 89 octane because the race tune runs on 91?
Old 04-06-2014, 08:23 PM   #20
2 Stangz's Avatar
Region: Nevada
Old 04-06-2014, 08:30 PM   #21
Originally Posted by 2 Stangz View Post
Lol I completely forgot that it required different gas untill this morning that it ran out and I was checking the tunes. Could it be that?
Old 04-06-2014, 09:33 PM   #22
2 Stangz's Avatar
Region: Nevada
If you're running a 91/93 octane tune and only have 89 or lower octane rating in the tank you're asking for problems. Although, I don't think it would trigger a check engine light. It's worth a shot though, definitely fill up with 91 or 93 next tank.
Old 04-06-2014, 09:35 PM   #23
It didn't trigger a check engine the o/d off light started flashing the check engine light never came on I'm gonna try it tomorrow and see how she runs
Old 04-06-2014, 09:41 PM   #24
Old 04-13-2014, 06:24 PM   #25
Do you guys think if I do a tranny flush will it help?
Old 04-13-2014, 06:59 PM   #26
If its having the issue with the race tune and not having the issue without, its the tune. You need a new tune or just run the stock tune. This is often what happens when you run a canned tune, especially from a shop that isn't an actual dyno tuner for local customers.
Old 04-13-2014, 07:21 PM   #27
Thank ya
Old 05-31-2014, 02:11 PM   #28
mustangmar2001's Avatar
@Tangtang2.0, did you ever solve this problem? My 2000 gt does the exact same thing and I need to figure out what to do? I was told to change the transmission fluid and filter and it would solve the problem!
mustangmar2001 is offline   Reply With Quote
Old 05-31-2014, 02:20 PM   #29
Who told you that? I haven't called bama I've been lazy about that haha but I was gonna call Monday for sure though
Old 05-31-2014, 02:28 PM   #30
I don't know how reliable that information is but a guy from bama said to do that.. Which is why I asked if you figured out your problem yet?
Old 05-31-2014, 03:30 PM   #31
Oh okay are you going to get your tranny flushed or no?
Old 05-31-2014, 03:41 PM   #32
I am going to change it either Monday or Tuesday..
Old 05-31-2014, 04:09 PM   #33
Let me know if it helps I'll let you know what bama tells me
Old 06-02-2014, 01:56 PM   #34
Hey I think I fixed the problem... Is that the exact code that you get too?
Old 06-04-2014, 03:15 PM   #35
Yeah I get the same code.. What did you find out?
Bama hybrid tune vs race tune tq hp curve rick9550 2011-2014 Mustang GT 7 07-14-2013 06:54 PM
bama race tune > bama hybrid tune 13 stang22 2011-2014 V6 Mustang 11 04-16-2013 05:26 PM
hybrid tune vs. race tune 13 stang22 2011-2014 V6 Mustang 37 03-30-2013 08:38 PM
Bama tune or lund tune or steeda tune Mustang32Bill 2011-2014 Mustang GT 89 11-12-2012 10:45 AM
Race Race!!! 1faststang Classic Mustangs 24 09-05-2011 05:18 PM
09:29 AM
