347 Stroker swap - Mustang Evolution
Old 04-01-2014, 11:56 PM   #1
FullyAutomatic's Avatar
Region: Mexico
347 Stroker swap
347 Stroker what you know about it?
Is there any good threads on here about the swap...
going to seriously look into this rather then building
the current 2v my car has
FullyAutomatic is offline   Reply With Quote
Old 04-02-2014, 12:21 AM   #2
Mile high JDF's Avatar
That I know of nobody on here has done a pushrod swap on a new edge. But if I remember right your need a K-member from a 94-95 GT and probably whatever wiring to run an engine like that. It might be a good idea to check the bigger forums like The Corral and SVTperformance for build threads or how-tos.
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 04-02-2014, 01:43 AM   #3
http://youtu.be/Bmb8YshZlqw
There a link to a guy on YouTube that did it on his new edge v6 deff had me thinking I rather pay for a engine swap than getting a whole new car note for the next 5 years.
Old 04-02-2014, 11:29 AM   #4
Are you saying, that this whole time, I've been on a "third rate" website?
I thought that this was the biggest, bestest, most... um... err... famousest on the whole internet...
We need to figure out a way to put ME on the map!
That confusing thread about the "426 Cobra jet" exhaust, got me thinking of the possibility of actually swapping a FE engine into one of these cars. Ford didn't offer a "426 CJ", the largest of the series was a 428. They were, relatively, light engines, for their displacement. Ford stopped using them because the casting process for the blocks was more expensive and there was a high (For Ford) percentage of casting failures.
Everything would have to be custom fabricated though...
Old 04-02-2014, 11:48 AM   #5
Ish416's Avatar
Why go through all the trouble to swap in a slow, heavy engine when you could just boost your current one?
Old 04-02-2014, 11:55 AM   #6
Haha I hope I didn't ruin your day right there.
I personally think a swap like that is not worth the headache fun to all the various complications you'll run into with changing up damn near everything on the car.
Old 04-02-2014, 12:08 PM   #7
You'll need an entire donor car from 94/95 and your current transmission will not bolt to a pushrod either.
And if you ARE going to swap in a pushrod you want a 351 based motor, not a 302 not to mention in many states its illegal to swap an engine that is not the same year or newer as your car.
So to answer your question, it can be done if you have a full donor car, a good set of tools and a place to work that preferably has a lift and you swap EVERYTHING over from the 94/95 car. Honestly, if you want a pushrod car, sell yours and buy a fox or a 94/95.
Old 04-02-2014, 12:17 PM   #8
I know it.
I was actually excited about that "426" thread when I saw the title...
Just finding a 428 CJ that someone doesn't think is "gold plated" would be the first of many obstacles.
Haha. I have one and you won't see me attempting the swap!
Old 04-03-2014, 02:51 AM   #9
Sbales88's Avatar
I've thought about putting an FE motor in my new edge as well, the 4.6 is a good motor but I prefer the old simpler stuff. The swap would be a PITA but I have most of the parts. I also have an FE motor already built but its only a 390, I bored it out put a bigger cam in it and had some very expensive head work done. But its running just shy of 500hp, which would be a ton of fun in a new edge
Sent from my SCH-R530U using Mustang Evolution mobile app
Sbales88 is offline   Reply With Quote
Old 11-25-2014, 11:51 PM   #10
lightning2189's Avatar
I just bought a motor off this guy and I'm pulling out my 4.6l now what all do I need to do for a 347 stroker to be dropped in will the motor mounts line up I need some in put
lightning2189 is offline   Reply With Quote
Old 11-26-2014, 12:04 AM   #11
This is exactly what I'm doing but on a 98 gt
Old 11-26-2014, 06:36 AM   #12
Again, you'll need most of the stuff from a 94/95 donor car. K member, mounts, fuel system, harnesses, transmission etc... Best bet is to find a wrecked 94/95 V8. Or sell your 4.6L and buy a 94/95 with a blown motor in otherwise good shape and just replace the motor.
347 Stroker numbers!!! WhiteCobra94 1979-1995 Mustang GT 5 02-16-2012 05:02 PM
96 347 Stroker for My 302 Fox? Qwik Four Six Pictures and Videos 5 11-25-2011 04:37 PM
347 stroker Stang89 1979-1995 Mustang GT 1 10-17-2011 06:20 PM
347 stroker vs. superK24 vs. blown V6....thoughts??? rinfield2004 Pre-2005 V6 Mustang 54 07-20-2010 11:30 PM
347 stroker powerhungry966 1979-1995 Mustang GT 10 10-12-2006 08:52 PM
08:44 AM
