Confusion!! - Mustang Evolution
Old 04-03-2014, 08:40 PM   #1
d_1212's Avatar
Confusion!!
Hey guys so I'm looking to get an aluminum driveshaft on am or late model for my 02 gt v8. To my understanding my yr has 28 spline driveshaft stock but when I look on those sites it says the 28 spline driveshaft is for v6. So do I need to upgrade my axles and diff just to get a new driveshaft?? Or was I wrong and the 31 spline is stock?? Heeeeeelp!!
d_1212 is offline   Reply With Quote
Old 04-03-2014, 09:18 PM   #2
You are confusing the splines on the axels with splines on the input shaft. Axel splines have nothing to do with drive shaft. Input shaft splines do though
Old 04-03-2014, 09:23 PM   #3
FullyAutomatic's Avatar
Region: Mexico
+1
FullyAutomatic is offline   Reply With Quote
Old 04-03-2014, 09:57 PM   #4
d_1212's Avatar
Ok still confused...does my car have 28 spline on the input shaft or 31? N I thought they all had to be the same? So I could throw in a 31 spline driveshaft yet my axles could be 28 spline??
Old 04-03-2014, 10:21 PM   #5
Mile high JDF's Avatar
Um you mean output shaft right...
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 04-03-2014, 10:27 PM   #6
This is the one you need. God forbid it doesn't work then just swap the yoke from the factory driveshaft to the aluminum. Axle splines have nothing to do with the driveshaft because the splined part of the driveshaft slides into the back of the transmission and the splines part of the axles slides into the differential itself.
http://www.latemodelrestoration.com/...num-Driveshaft
Old 04-03-2014, 10:39 PM   #7
d_1212's Avatar
Right on thanks very much appreciate the help
Old 04-04-2014, 04:09 AM   #8
Sho nuff
Old 04-04-2014, 12:29 PM   #9
Someone on here made this mistake awhile back buying a 28 spline DS because they had 28 spline axles. But yes you can just pull the snap rings out of the u-joints and swap the input shafts if you mess it up, everything else is the same.
The T-5 transmissions in the 5.0 pushrods are 28 spline output as well as the old Tremec 3550s. The 96-04 Modulars use either a T-45 or a T-3650 which both are 31 spline. Unless you have a 03/04 Cobra with the T-56, then you are 27 spline GM style.
Tire Confusion.. charcoal Mustang Wheels & Tires 7 01-13-2009 03:31 PM
Coolant Level Confusion IMP Pre-2005 V6 Mustang 1 10-10-2008 09:27 PM
HS Football Confusion Tonight Riversnake Pictures and Videos 2 09-07-2007 11:43 PM
WTF media confusion! Thomas91169 The Bar 2 07-18-2007 05:06 AM
Need help with my confusion..... Vinnietbird 1979-1995 Mustang GT 16 02-16-2006 03:17 PM
10:03 PM
