Not good - Mustang Evolution
Old 04-04-2014, 05:55 AM   #1
Doe_Rae_mi's Avatar
Not good
Found water coming out my strut. And it's making bad popping noises. Anyone have an idea of what it could be?
Old 04-04-2014, 06:05 AM   #2
Are there any holes/rust or anything like that on them? Cracked?
Sent from my C811 4G using Mustang Evolution mobile app
2010 GT Done: FR Intake Manifold-FRPP Hot Rod Cams-Granatelli 62mm TB-BBK Ceramic Longtubes-BBK Catted X-pipe To do:-One piece aluminum driveshaft-Gears-Staggered wheels when my tires are done
theonekyle is offline   Reply With Quote
Old 04-04-2014, 06:20 AM   #3
Doe_Rae_mi's Avatar
No I looked can't see anything like tht lol
Old 04-04-2014, 06:22 AM   #4
Do you know if their oil filled or air?
Old 04-04-2014, 06:28 AM   #5
Either way a strut is a sealed unit, if water is coming out of it that isn't good. All they are is compressing cylinders, if there's a leak you lose that compression. Oil leaking out is a quick sign of failure and if they are air struts/shocks use a soapy water mix and try to make bubbles. Either way I would start looking at New ones. Make sure you take advantage of any part warranty if you have them.
Old 04-04-2014, 06:34 AM   #6
Doe_Rae_mi's Avatar
Not sure just stock 03 gt struts.but like u said u will def need to start looking at new ones lol
Old 04-04-2014, 06:38 AM   #7
Ya man, I mean thats an 11 yr old strut and stock replacement isn't too expensive for an 03. But even a new one can go bad quick under hard driving or bad roads. Usually you see it in truck shocks from off roading, the welds rust from poor paint and then crack and leak. And all those flashy rubber boots do is hold dirt and water in there.
Old 04-04-2014, 08:30 AM   #8
Doe_Rae_mi's Avatar
Yea:/ well thanks man!
Old 04-04-2014, 08:57 AM   #9
Np
Old 04-05-2014, 09:08 AM   #10
Doe_Rae_mi's Avatar
Not good
Where are the strut and/or the control arm bushings??? ganna see of that will fix it
Old 04-05-2014, 09:49 AM   #11
Doe_Rae_mi's Avatar
I'm starting to think it's some sort of bushing or spacer or something that has worn out
Old 04-06-2014, 01:15 PM   #12
Doe_Rae_mi's Avatar
Could the noise be because my ball joints are tac welded?
Old 04-06-2014, 01:41 PM   #13
Doe_Rae_mi's Avatar
Checking rn and the strut isn't making tr noise. But wheneve I push down the noise occurs. Also wen I turn the steerin wheel all the way to the left
Old 04-06-2014, 01:45 PM   #14
Doe_Rae_mi's Avatar
Name:	ImageUploadedByMustang Evolution1396813466.461864.jpg
R these little prong thigs supposed to move alittle bit and make a knocking noise? Bc that's what it sounds like I'm hearing
Old 04-06-2014, 03:00 PM   #15
Ball joints tack welded?!?!!??
Sometimes those studs are a little loose but they tighten up when the wheel is torqued on at 100lbs.
Old 04-06-2014, 03:13 PM   #16
Mile high JDF's Avatar
Steeda X2 have had issues with popping back out of the control arms so the solution is to tack it in
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 04-06-2014, 03:16 PM   #17
Interesting.
Old 04-06-2014, 03:16 PM   #18
Doe_Rae_mi's Avatar
Ahhhhhh yes the guy said they would stay in lol. Could that be the noise possibly?
Old 04-06-2014, 03:23 PM   #19
When is it making this popping noise? Does it happen when you go over bumps? Have any pictures of this leak from the strut?
Old 04-06-2014, 03:24 PM   #20
If you have the original struts and shocks, that is the first thing that I would be suspicious of.
The strut bushings are on top of the struts but since you have plates I'm not sure if MM uses the stock ones or if they have some proprietary bushing or bearing.
Your car is pretty low, youve probably blown out the struts...
Old 04-06-2014, 03:35 PM   #21
Doe_Rae_mi's Avatar
The popping noise happens when I go over hills. It's a pop and a creak at the same time. I put the car on a stand and jacked up the strut and it didn't make the noise at all. It was clean.
---------- Post added at 05:35 PM ---------- Previous post was at 05:34 PM ----------
That's what I was thinking as well
Old 04-06-2014, 03:36 PM   #22
Doe_Rae_mi's Avatar
I'll upload a vid to YouTube and post it here
Old 04-06-2014, 03:46 PM   #23
Doe_Rae_mi's Avatar
Not good
While it's uploading.... Do you have a idea?? Originally I thought the strut. But now I just don't know
Old 04-06-2014, 04:41 PM   #24
Doe_Rae_mi's Avatar
http://youtu.be/r6NUypaEPWM
http://youtu.be/76TWgb6wvWw
2 different vids of the noise
Old 04-06-2014, 04:47 PM   #25
Hmm check your sway bar end links
Old 04-06-2014, 04:51 PM   #26
Doe_Rae_mi's Avatar
Not good
Yea they did look pretty rough. I hope that's it. But is there a way I could test it before I going burning money?i also just did some research and a guy said the end links were causing a noise when he was going over bumps.
Old 04-06-2014, 04:58 PM   #27
You can visually check them to see if they're broken
Also wiggle them, they should hardly move at all.
Old 04-06-2014, 05:06 PM   #28
Doe_Rae_mi's Avatar
If not broken could bad bushings cause it as well?
Old 04-06-2014, 05:06 PM   #29
The bushing would have to be missing completely to clunk like that
Old 04-06-2014, 05:25 PM   #30
Doe_Rae_mi's Avatar
Aahhh ima check tomorrow. Thanks man!
Old 04-07-2014, 10:29 AM   #31
Doe_Rae_mi's Avatar
U were right mile high it's the sway bar end links! Right when I jiggled it, it made the noise! Thanks man!
Old 04-07-2014, 01:12 PM   #32
Awesome! Glad it was something easy. The tech who installed your ball joints may not have tightened it down all the way.
Old 04-11-2014, 06:38 AM   #33
Just got back on and saw you got it sorted. Good news, yeah end links went out in my jeep all the freaking time! P in the A
Car would not start-could not be jumped-then started richardcrowson1 Pre-2005 V6 Mustang 8 06-02-2010 08:25 PM
1976 ford mustang will not start, not headlights come on, it is not the battery, why? eifion Classic Mustangs 6 08-24-2009 03:12 AM
not sure if yall have seen this or not SrATEX The Bar 5 07-28-2005 10:36 AM
Not really new and not totally a newbie... wendyc New Member Introductions & Greetings 23 01-10-2005 05:10 AM
10:05 AM
