MAS problem - Mustang Evolution
Old 04-05-2014, 05:11 PM   #1
saleenfan04's Avatar
MAS problem
I just installed SCT MAS 90m Be4 I had lighting 90m my question is do I still need dyno tune up? Normal traffic first and 2nd gears cars feel like it's about to die on me and it's automatic Is cuz it's getting so much air not fuel? Anything would help?
saleenfan04 is offline   Reply With Quote
Old 04-05-2014, 05:15 PM   #2
jonathanadams22's Avatar
You could go with a flash tuner
jonathanadams22 is offline   Reply With Quote
Old 04-05-2014, 05:16 PM   #3
I have supercharger sorry forgot to mention
Old 04-05-2014, 05:18 PM   #4
Then you need a dyno tune for sure it's gonna run you around $600 though.
Old 04-05-2014, 05:24 PM   #5
I got a dyno tuneup right after I installed my supercharge. The only change I currently made is changing the mass air sensor.
Old 04-05-2014, 09:16 PM   #6
cliffyk's Avatar
You need a new tune it is very unlikely that the SCT and Lightening MAFs would have the same transfer curves.
In the tune the MAF transfer function maps the MAF out signal to an airflow (in lbm/h). The PCM then uses that lbm/h as the basis for injector pulse width and ignition timing.
Just curious. why are you changing from the 90 mm Lightening unit--it is good up to 500+ HP? Unless it's output was pegged at high engines speeds and WOT then neither the SCT BA-2600 or BA-3000 will make any noticeable difference...
Old 04-05-2014, 09:33 PM   #7
I had to get a new mass air sensor because I had taken the other one out to clean but in the process I broke one of the screws. I tried to tighten it back up but the mass air sensor was just loose and shaking so it felt like it wasn't getting the full air through. So I bought a new one and ended up getting this one even though I am not going over 420 hp.
Old 04-05-2014, 09:52 PM   #8
cliffyk's Avatar
You should have received a transfer function (curve) document with the MAF--IIRC SCT provides a 9-point map with every MAF. If you have that I can convert it to a 30-point map. This would be useful for your tuner. I will also compare its curve to the Lightening curve and see if the MAF is the problem.
Do you have the BA2600 or BA3000 unit?
Old 04-05-2014, 10:17 PM   #9
I don't think I do have that but m using 2600
i hate x-mas eve's eve timpryor The Bar 12 12-23-2004 05:34 PM
The X-mas mods are on the way. Dom Pictures and Videos 8 12-10-2004 10:04 PM
Can't Wait till X-Mas!(Winter Mods) Black95GT The Bar 13 10-28-2004 05:27 PM
Hows this for a little Pre X-mas gift??? Crispy Mustang Audio & Video 14 12-12-2003 09:52 AM
Look what x-mas gift i won on ebay! HELL YEAH!!!!!!!! Autobadges.com The Bar 17 11-08-2003 02:59 AM
12:19 PM
