How much would it cost? - Mustang Evolution
Old 04-08-2014, 04:00 PM   #1
d_1212's Avatar
How much do u guys think ballpark a shop would charge to install the poly bushings set on American muscle?
Comes w tie rod end boot
Sway bar end link set
Upper strut mounts
Spring isos
Control arm bushings
Rear axle bushings
And steering rack
I'd consider doing some myself but I'm def a rookie when it comes to working on cars so I'd rather leave it to the pros I'd probably end up doing more bad than good. Since I bought my car the squeaks and random noise has been getting worse n worse I figure getting these installed might help me narrow down some of the sounds and eliminate some all together. I have steeda ball joints on the way and I'm planning on getting a new driveshaft as well. Moneys a bit tight but the car is embarrassing to drive ATM and I really want it in good shape for summer. Thanks for all the help M.E
d_1212 is offline   Reply With Quote
Old 04-08-2014, 04:26 PM   #2
FullyAutomatic's Avatar
Region: Mexico
MY opinion would be not to buy the kit.
They will charge by the hour 70-100 + the cost of the kit you buy...
also, why are you buying a new drive shaft? is there a reason behind it? is it aluminum? .. seems like your money could be better spent.
Look into buying new shocks and struts and springs, lower control arms. remove your quad shocks and take a look at your rotors and pads... I bet that rite there would not only eliminate a lot of the squeaks but would be money better spent.
I assume if they are replacing the bushings they may come back to you and tell you parts that will need to be replaced and not just the bushings...
FullyAutomatic is offline   Reply With Quote
Old 04-08-2014, 04:47 PM   #3
d_1212's Avatar
Ya the ds would b aluminum. I have a grinding/squealing noise when my cars been sitting while I take off slowly that goes away once the car is warm Im guessing it could b a few things but I think a new ds could b a good start, quicken acceleration and its something I could do myself in the driveway. I wanted to get the u joints done so I would b killing two birds kinda thing. My car is over 10 years old n I don't think the previous owner did much preventative maintenance. I have a feeling most of the bushings will start to go if they haven't already.
How much would a bottom end cost to be built.? 08GTsleeper 2005-2010 Mustang GT 4 12-05-2011 12:34 PM
How much would it cost to turn a 1994 mustang into a stick shift? abiram Pre-2005 V6 Mustang 2 08-19-2009 10:24 AM
How much would a 1965 Ford Mustang Fastback Cammer cost me restored? imported_raymond Classic Mustangs 3 08-19-2009 12:38 AM
How much would it cost to change a stick shift 1967 Ford Mustang Fastback? jeremias Classic Mustangs 1 08-18-2009 09:23 AM
How much would it cost to repaint a 1967 Mustang? tully General Mustang Discussion 2 08-17-2009 12:01 PM
08:17 PM
