Noise while stearing, and vibration at 90+ mph - Mustang Evolution
Old 04-09-2014, 06:29 PM   #1
Speed_Mister's Avatar
Region: Arkansas
So I have a little noise when I turn my wheels it's not a whining noise but it sounds like something isn't greased very we'll, and also I have a small vibration going on at 90+ mph don't know if it has any relation to my steering noise. What y'all think?
2004 Mustang GT 5 Speed
Full Bolt Ons
370rwhp 470rwtq
12.1 @ 117.9 (1.7) in 1/4th
7.6 @ 92.1 (1.6) in 1/8th
Old 04-09-2014, 07:07 PM   #2
Doe_Rae_mi's Avatar
Hmmmmmm where u been going 90+ huh!? Jk check Ur balljoints
Old 04-09-2014, 07:09 PM   #3
Region: Arkansas
I lifted my car and tried wiggling my tire and I had a little soft wiggle side to side on both sides and one side had rough wiggle when I shook it up and down.
Full Bolt Ons
370rwhp 470rwtq
Old 04-09-2014, 07:26 PM   #4
Clean98 Gt's Avatar
Worn ball joints will make it sqeak. Sucks ford didnt put grease fittings on them. The vibration may be coming from maybe your tires being out of balance or maybe a weight came off. Or the vibration could be from your inner and outer tie rods. It could be a couple of those things I would get your tires looked at and while they're at it and they have the car up have them check your inner and outer tie rods.
Clean98 Gt is offline   Reply With Quote
Old 04-09-2014, 07:30 PM   #5
Region: Arkansas
I don't let other shops touch my car I have a friends shop we use and fix out own stuff. What would I look for if the inner and or outer tie rods are making the noise and bib and how would I fix it?
---------- Post added at 07:30 PM ---------- Previous post was at 07:30 PM ----------
Probably gonna take stuff apart and grease my ball joints what kind of grease should I use?
Full Bolt Ons
370rwhp 470rwtq
Leaking oil around my power stearing pulley Speed_Mister 1996-2004 Mustang GT 1 03-27-2013 03:25 AM
1966 6cyl with T5 conversion with vibration without load >60 mph Watchtrader Classic Mustangs 0 08-10-2012 06:33 PM
Stearing Issue... lConnerl 1996-2004 Mustang GT 9 01-12-2012 01:34 PM
Shattering noise and vibration when engaging the clutch only on first gear and reverse? wolfe General Mustang Discussion 3 03-10-2010 05:40 AM
Stearing wheel question Narcosis Pre-2005 V6 Mustang 5 07-16-2009 12:41 PM
04:18 AM
