Torque arm bar worth it or not? - Mustang Evolution
Old 04-10-2014, 08:59 AM   #1
So I saw in AM that they have a torque arm bar for like 400 something. So I was just curious on what people think about these or if anyone has one installed and does it help for the money you pay ?
southernstang00 is offline   Reply With Quote
Old 04-10-2014, 10:40 AM   #2
I have one sitting in my room that I need to find time to put in so I'll let you know what I think of it...... But from all reviews it's one of the best things you can do to a solid axle car. Converts to a 3 link rear suspension set up so there is no binding and it makes your car just plant to the road through turns. Also your car will launch like a mother ****er
Old 04-10-2014, 10:40 AM   #3
Name:	ImageUploadedByMustang Evolution1397148034.119198.jpg
Old 04-10-2014, 11:46 AM   #4
Yep that's the one I was looking at getting. I need something because I'm running more boost and is your car lowered ? Did you change your rear control arms ? Let me know if you have to weld them to the sub frame connectors if you have them. At the same time let me know how it does on traction before I get mine and if I get mine before you install it I will do the same.
Old 04-10-2014, 11:56 AM   #5
FullyAutomatic's Avatar
Region: Mexico
what all needs to be changed to take advantage of the torque arm
FullyAutomatic is offline   Reply With Quote
Old 04-10-2014, 12:04 PM   #6
Mile high JDF's Avatar
Don't you have to install a panhard bar with the torque arm since you're deleting the upper control arms?
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 04-10-2014, 01:00 PM   #7
As I was looking at the install kit you remove the upper shock/ arms when you install the ta. Then it tells you to remove the weight ( not sure of the technical term for it) on the bottom of the rear end. Then if you install the mm rear control arms with all that said and done you have removed like 40 something lbs according to the directions. You have to install a bar up near the trans mount.
Old 04-10-2014, 01:22 PM   #8
bucko's Avatar
Are these the same as what used to be called "ladder bars"?
Old 04-10-2014, 01:37 PM   #9
Hmm interesting. I always thought it needed the panhard bar to re center the axle
Old 04-10-2014, 01:42 PM   #10
The Torque Arm requires the installation of full length weld in subframe connectors and a Panhard Bar.
Old 04-10-2014, 02:06 PM   #11
Site Sponsor
Sponsor
AMWill's Avatar
I've heard a lot of great things about the MM torque arm kit! I can't say I've seen one installed before or have experienced it in person yet though. I'm interested in your guys feedback if one of you plan to give the torque arm a shot. Especially for an extreme power application!
Shane
Toll Free: 866.727.1266
Free Same-Day Shipping!
Old 04-10-2014, 03:00 PM   #12
Shane
Shane!!!! AM NEEDS a Panhard Bar for the 99-04!!! You can't install it without so people are going to have to go elsewhere then. I bought my TA from you guys but the PHB I had to get elsewhere.
Old 04-10-2014, 05:25 PM   #13
Kind of. They accomplish much the same thing, keeping the differential housing from rotating, only in a more sophisticated way on a 4 link suspension. Ladder bars are typically for a leaf spring suspension, and you probably remember the less effective "traction bars" as well...
Old 04-10-2014, 11:01 PM   #14
Look I'm the picture that was posted it might be that. I know you have to loose up the trans mount and stuff.
Old 04-10-2014, 11:02 PM   #15
Isn't a that the bar with the hole in the middle ?
Old 04-10-2014, 11:04 PM   #16
I'm going to see if I can post the directions tom.
Old 04-10-2014, 11:28 PM   #17
You have to remove a crossmember up front so you can put in the Torque Arms mounting bracket up there which the actual bar receives into.
Old 04-10-2014, 11:54 PM   #18
The what is a panhard bar ?
Old 04-11-2014, 12:02 AM   #19
The part up top on the axle with the angled bar is the Panhard Bar, the huge brace on the axle is the Torque Arm, if you look up the Torque Arm you will see the brace I was talking about. Notice that the brace at the front of the Torque Arm is connecting to the Subframe connectors, that is why the Subframe connectors are required.... The Panhard Bar is required because you take off both of the upper control arms when installing the Torque Arm, so something has to keep the axle centered and you don't want the axle to go side to side because it can flex where its connected to the Subframe connectors and break something.
Old 04-11-2014, 12:07 AM   #20
BTW that picture can be considered porn to some people.
Old 04-11-2014, 12:46 PM   #21
Site Sponsor
Sponsor
AMWill's Avatar
Do you know what the rough measurement of the Panhard Bar is on this setup? I'm wondering how close it would be to an 05-14 adj Panhard Bar. It you could use one of those, that would be great. Although, the one you posted up looks a bit shorter.
I agree we need to offer something there!
Shane
Old 04-11-2014, 09:25 PM   #22
Shane
Well guess I will have to wait on getting the ta until yall get a panhard bar. Unless someone else has it but rather order it from AM. Maybe yall go could get a vendor to start getting them from ?
Old 04-11-2014, 09:27 PM   #23
Thanks for the picture and explain it makes sense now guess I will have to wait on getting the ta until I find a panhard bar.
Old 04-14-2014, 10:21 AM   #24
Site Sponsor
Sponsor
AMWill's Avatar
I'm confident we'll find a solution for the panhard bar rather quickly. Whenever we're missing a required component, we're always quick to act. The last thing we want to do is leave our customers hanging!
I'll post back as soon as I get word a on a resolution. Thanks for the excellent feedback everyone!
Shane
Old 04-14-2014, 10:49 AM   #25
Shane
The thing is with 99-04 it's not just the straight bar, since the car doesn't come with one you need the entire thing.
Name:	ImageUploadedByMustang Evolution1397494166.375182.jpg
I can measure when I get home later.
Old 04-14-2014, 10:50 AM   #26
I got most stuff from AM, but my Panhard Bar I got from Stangmods. All of the suspension is Maximum Motorsports so it shouldn't be too hard for AM to set up a deal with them.
Old 04-14-2014, 11:26 AM   #27
Shane
Let me know what all I would need with the ta bar. Maybe get a good deal for bring it up that yall dont have a part that should go with a part yall carry.
---------- Post added at 12:26 PM ---------- Previous post was at 12:25 PM ----------
So in addition to the ta bar and panhard bar you need another piece ?
Old 04-14-2014, 11:29 AM   #28
No, it's the Panhard Bar.... The actual thing is just that silver rod in one of my pictures. If you had a 05+ and got a new ones that is all you would get. But that other black piece is the mount for it since 05 and down doesn't have it. That's why the Panhard Bar is more expensive than 05+
Old 04-14-2014, 11:55 AM   #29
So I would need two things. The ta bar and the panhard bar for a 2000 ?
Old 04-14-2014, 03:56 PM   #30
Polar Bear's Avatar
Region: Asia
Steve
Polar Bear is offline   Reply With Quote
Old 04-14-2014, 04:24 PM   #31
The Torque Arm requires weld in subframe connectors and the Panhard Bar before it can be installed. It is HIGHLY recommended to do the LCAs also.
Old 04-14-2014, 04:43 PM   #32
Yeah I already got them installed and the LCA are coming soon. Guess I need to wait on AM to get the panhard bar
Old 04-15-2014, 02:48 PM   #33
Site Sponsor
Sponsor
AMWill's Avatar
Attachment 153933
You're right. I kept thinking the torque arm kit came with the panhard bar bracing. Not sure why, but thanks for clarifying for me. I've already added this to my New Product Suggestions list. I'm sure well be able to bring in the panhard bar assembly shortly.
Thanks again!
Shane
Old 04-15-2014, 05:10 PM   #34
Region: Mexico
AM should do an install video of the torque arm bar on a 99-04 project car when they do get the panhard.
Old 04-15-2014, 06:06 PM   #35
I agree
How much torque to use on strut bar? Ranger052 2011-2014 V6 Mustang 15 03-16-2014 06:07 AM
Good list? anything worth or not worth getting? Jetsnix Pre-2005 V6 Mustang 58 07-22-2012 11:06 PM
torque converter worth it? tigerfan2771 Pre-2005 V6 Mustang 7 09-19-2008 11:22 AM
Torque Arm for a 7.5 rear axle fastmustangs1 Pre-2005 V6 Mustang 6 02-17-2005 02:01 PM
How to: Roll Bar (light bar install) cagedthought Mustang Audio & Video 12 11-02-2004 08:18 AM
04:53 PM
