It Happened!! The dreaded Heater hose broke at the intake Manifold - Mustang Evolution
Old 04-13-2014, 08:32 AM   #1
Lorenzod02gt's Avatar
This Sucks! Where can I get the best deal on a new Intake manifold??
Lorenzod02gt is offline   Reply With Quote
Old 04-13-2014, 09:55 AM   #2
BigB227's Avatar
I bought mine from summit racing a couple years ago for around $180, I had the same problem and just this year I had my heater hose blow off from the fire wall.
BigB227 is offline   Reply With Quote
Old 04-13-2014, 09:59 AM   #3
AM has the full kit with gaskets for 199 or the Ford one with no gaskets is 215
Old 04-13-2014, 01:54 PM   #4
XSlashDashX's Avatar
Ebay. Bought mine from LMR though for 240 I believe. Been awhile. Click image for larger version
Name:	ImageUploadedByMustang Evolution1397418736.573525.jpg
Old 04-13-2014, 02:02 PM   #5
Yeah this Totally sucks so bad
Old 04-13-2014, 02:14 PM   #6
FullyAutomatic's Avatar
Region: Mexico
every new part is a good part...
FullyAutomatic is offline   Reply With Quote
Old 04-14-2014, 07:17 AM   #7
DO NOT BUY THE AM $199 KIT!. That one is the Dorman and it is junk I don't care if the gaskets are made of gold. If you did buy the Dorman, send it back because you are essentially bolting a NPI intake on your PI engine if you install it.
You want the FRPP one which is actually the PI intake. You can get that for $215 shipped from LRS as well, I just bought one from them a few months ago and it shipped the day I ordered it and came very nicely packed. Get the Fel-Pro gaskets for $25 on Rockauto and do the install. Torque the intake bolts to 22 ft lbs in the correct sequence.
Getting a new PI intake is good insurance anyway because at the age these cars are at now, the plastic under the metal crossover where the t-stat is usually warps and leaks. Bad design of Ford's part but at least it takes awhile for it to happen.
If you need any help with the intake let me know but its very straightforward.
Old 04-14-2014, 07:45 AM   #8
I ordered the Ford part that was 215 from AM and the Fel pro gaskets
Old 04-14-2014, 09:17 AM   #9
Good deal. You also are going to want a tstat gasket which you can get locally anywhere. You'll need a torque wrench too if you don't have one already.
Old 04-14-2014, 01:46 PM   #10
Anything else I should replace while it's all apart?
Old 04-14-2014, 07:45 PM   #11
The heater core hoses since they are easy to get to while the intake is off, if your COPs are high mileage, rebuild them while they are off, injector o-rings, spark plugs are really easy to get at with the intake off although they are easy enough to do with it on too.
Oh also, a trick to get all the air out of your system when you re-fill the coolant after you do the intake and get everything buttoned up. Leave the temp sensor out of the crossover while you are putting new coolant in. That is the highest point in the system it'll let all the air escape while you are filling. Wrap a rag around the opening when you get close just keep filling a little at a time and it'll burp on its own till its done. Then coat the temp sensor threads with some black RTV, install and let it setup and you are done.
Heater hose came off manifold 96carsrus 1996-2004 Mustang GT 0 11-17-2012 07:19 PM
Quick fix for heater hose spout on intake? 96Roushgt 1996-2004 Mustang GT 1 09-06-2012 11:02 AM
Heater hose 02silvermonster 1996-2004 Mustang GT 8 04-08-2012 11:37 PM
I have a 2001 mustang and the inside fan where the heater/ac air comes out and it broke!? Shanahan 1996-2004 Mustang GT 1 12-19-2011 11:47 AM
My heater scuks in fumes when I turn on the heater jaynez31 Pre-2005 V6 Mustang 3 02-08-2006 06:44 PM
08:08 PM
