Hard times for the stang... - Mustang Evolution
Old 04-15-2014, 05:39 PM   #1
ty98gt's Avatar
Hey guys
So the last few weeks for my car have been rough, partially my fault too.. Last week one of the cats on my x pipe started rattling really bad so decided to swap back to the stock h pipe until i bought an offroad x.
When pulling the x pipe off, i was removing the passenger side manifold bolts when my wrench tapped the starter and it made a spark sound. It was then that i realized I totally forgot to disconnect the battery..(yes I'm a dumbass, I know). I didn't think much of it at first and finished swapping the pipes.
So after everything was done i went to start the car and it just kept cranking. The car just cranks and cranks but doesn't even begin to turn over. The battery light is on and the theft light is flashing really fast when the key is engaged and when the car is cranking. Ive tried a bunch of stuff so far and nothings worked...
My mechanic says he has no idea what the problem is and that its not the starter and that its a computer/electrical issue, so I'm at a loss. Could this be a PATS issue? My car has the bama race tune on right now too btw and ive read that a tuner could disable PATS.
Any thoughts?
Engine/drivetrain mods: Pro 5.0 Short Shifter, Dragon Plenum-75mm, Accufab TB-70MM, K&N FIPK GEN.2 Air Intake, Bassani Cat Back Exhaust,Bassani Catted X Pipe, 3.73 FRPP Rear Gears,Ford Racing TA Rear Diff Cover,
Bunch of suspension goodies
ty98gt is offline   Reply With Quote
Old 04-15-2014, 06:06 PM   #2
nhcowboy's Avatar
I assume you have since then disconnected the battery, waited, drank a beer, waited, then reconnected?
2011 Black Mustang GT Premium
Corsa XO & Sport AB/Airaid/Bama 93R
Best 1/4 mile to date 60' 2.009
12.538 ET @112.33
100+ Deg 85 Hum RPR 3PM 1/2 tank street tires
nhcowboy is offline   Reply With Quote
Old 04-15-2014, 06:09 PM   #3
ty98gt's Avatar
Oh yaa haha, this all started a few days ago. I disconnected the battery for a few hours then reconnected and its still doing the same thing..
Old 04-15-2014, 08:18 PM   #4
FullyAutomatic's Avatar
Region: Mexico
wouldn't it be your alternator if your battery light is on.. test it
FullyAutomatic is offline   Reply With Quote
Old 04-15-2014, 08:32 PM   #5
Mile high JDF's Avatar
Sounds like a pats issue. I'd get it shut off and see what jappens. Do you have a spare key you could try?
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 04-15-2014, 09:36 PM   #6
ty98gt's Avatar
I don't think its the alternator unless it got fried somehow from my wrench hitting the starter, ill check it anyways though. I do have a spare key, my key was in the ignition when it happened, but it wasn't in the on position. Maybe the spark screwed the up how pats recognizes that key?
Old 04-16-2014, 10:51 AM   #7
If you haven't already, check the high current (under hood) fuses. Good possibility. Good luck!
Super_Ranger is offline   Reply With Quote
Old 04-16-2014, 11:13 AM   #8
ty98gt's Avatar
My mechanic and i checked the fuses, they're all good except the ecm fuse but when we replace it with a new one, it keeps blowing. I have no idea now...
Old 04-16-2014, 11:15 AM   #9
Try another ecm if it keeps blowing fuses. Sounds internally shorted.
Old 04-16-2014, 11:17 AM   #10
ty98gt's Avatar
Would an ecm reflash help the problem?
Old 04-16-2014, 11:19 AM   #11
I personally do not thinks so. Especially if it blowing fuses. That is a tell-tale sign something is shorted to ground. Cannot reflash if its shorted. I could be wrong but i don't think so.
Old 04-16-2014, 11:41 AM   #12
ty98gt's Avatar
Man..this has become a f***ing horror story. Thanks for the info though
Old 04-16-2014, 12:38 PM   #13
Check boneyard! ECM's are a dime a dozen on out cars!!!!
Old 04-16-2014, 12:41 PM   #14
Until you have to get PATS reprogrammed... or just buy a tuner and have it turned off.
Old 04-16-2014, 01:53 PM   #15
ty98gt's Avatar
I already contacted bama and they're sending me updated tunes with pats turned off. But I tried returning the car back to stock and the tuner gives me trouble code 1028 and says the computer is not connected...fml
05 stang hard shifting Imaboss 2005-2010 V6 Mustang 2 09-09-2013 08:19 PM
How hard are you on driving your stang? I_luv_HP&trq The Bar 22 12-09-2005 09:55 AM
Good times, good times fast64 The Bar 22 11-29-2005 01:16 AM
Pick up 2003 Auto on Sat, going to track on Sun, what times? Jime Pre-2005 V6 Mustang 30 11-04-2004 11:33 AM
Im heading out to the track tonight! **TIMES ARE POSTED** Zim Pre-2005 V6 Mustang 20 07-21-2003 10:14 PM
06:21 AM
