What battery do you have - Mustang Evolution
Old 04-16-2014, 10:59 AM   #1
FullyAutomatic's Avatar
Region: Mexico
I have been using a crappy battery all winter and its time to stop putting strain on everything.
What battery do you have?
was thinking red top"?
FullyAutomatic is offline   Reply With Quote
Old 04-16-2014, 02:06 PM   #2
Interstate
Old 04-16-2014, 02:08 PM   #3
Tyoung68's Avatar
I have a redtop and i haven't had a problem even after sitting for 3 months
Old 04-16-2014, 02:26 PM   #4
Tyoung68's Avatar
Old 04-16-2014, 02:32 PM   #5
Ok Travis... We've got it... No problems with the Red top even after sitting for three months...
Old 04-16-2014, 03:09 PM   #6
Region: Mexico
I guess Ill go with the red then
Old 04-16-2014, 08:33 PM   #7
Tyoung68's Avatar
Haha glad i could help
Old 04-16-2014, 08:44 PM   #8
Nope, you go YELLOW. Yellow is a Red Top except deep cycle. This means if you accidentally drain it and let it sit for awhile it'll come right back. Do that with a Red Top a few times and bye bye Red Top.
Honestly though they are overkill. Get a good Napa sealed battery and you won't have a problem. I keep mine on a tender since I only really drive it when its nice out but its been over 2 years and she fires right up every single time.
Old 04-16-2014, 08:48 PM   #9
Tyoung68's Avatar
Deep cycles are bad for regular car i thought
Old 04-16-2014, 11:04 PM   #10
Yellows are mostly for people who have sound
wicked2v is offline   Reply With Quote
Old 04-17-2014, 05:55 AM   #11
Why would you think that?????
They are for ppl who want a battery that won't be a brick if it discharges by accident. Yeah they are used in sound systems but they are great as your main starting battery too. My 610 provided a ****ton of cranking power for a 11:1 brand new motor when the Napa couldn't cut it.
However, for a regular 5.0 or 4.6 there is 0 reason to use an Optima over a box store special unless it is going to sit for extended periods of time. And then its probably a good idea to pull the battery and bring into the garage/basement and put it on a tender if you can't run an extension cord out to the car.
Old 04-17-2014, 05:58 AM   #12
I've been running a red top for the last 4 years in the cobra. Every spring I take it to the local az as I don't have a tender or charger for a gel battery.
Sent from my massive johnson.
Old 04-17-2014, 07:45 AM   #13
I used a regular ebay trickle charger on my yellow. Same one I have now on the normal battery in my 98. Works fine either way. I'm not knocking the red top or the CCAs it provides, I'm just saying you get the same thing with the Yellow plus the deep cycle.
Old 04-17-2014, 11:00 AM   #14
Tyoung68's Avatar
Well im taking electrical automotive classes at my cc and i thought i remember my teacher saying something how its bad to use a deep cycle for cars but i cant remember why. Ill ask him on monday.
Old 04-17-2014, 11:04 AM   #15
Region: Mexico
my current battery is junk. We had such a bad winter that the battery would be dead and need a jump at least once every 2 weeks... car has been sitting for past like 4 days.. I should go start it to make sure it will start when I need it 2... I'm guessing it will struggle..
so what I am taking from this... is red top = just as good as walmart battery
yellow top = if I leave my lights on and battery dies.. shut lights off, come back later .. should start up?... sounds like a life saver lol
Old 04-17-2014, 01:39 PM   #16
Tyoung68's Avatar
Almost a yellow top would just last long with your lights on longer than a regular batter would last
Old 04-17-2014, 02:05 PM   #17
Tyoung68's Avatar
Old 04-17-2014, 03:07 PM   #18
No that is not what deep cycle means... and a red top has way more cold cranking amps than a normal battery. I just think it's overkill for a regular motor.
Sent from my VS980 4G using Mustang Evolution mobile app
Old 04-17-2014, 03:10 PM   #19
Region: Mexico
Old 04-17-2014, 04:07 PM   #20
I mean if it sits discharged for awhile it will recharge when you put it on a charger. A non deep cycle battery usually can do this once or twice before it is damaged. Yes I could have worded it better originally.
Old 04-17-2014, 08:31 PM   #21
surfinglbi23's Avatar
Are you sure you don't have a drain on the battery? I'd start there. Check your grounds, connections etc.
surfinglbi23 is offline   Reply With Quote
Old 04-18-2014, 09:45 AM   #22
XSlashDashX's Avatar
I use walmart battery. If it goes bad their is a walmart like in every town to get it replaced.
What car would you rather have if you could have either??? 1965 Ford Mustang or 1963 Mercury Comet? colton Classic Mustangs 3 08-29-2009 12:40 PM
For all you who THINK you have a high post count... SpectorV The Bar 14 12-19-2004 06:00 PM
And you think you have ant problems.. lowflyn The Bar 24 10-13-2004 06:43 AM
What Fox-bodies have you, or do you, own? 427windsorman Mustang Audio & Video 8 02-11-2004 02:05 PM
08:17 AM
