Quick install ? - Mustang Evolution
Old 04-17-2014, 04:33 PM   #1
11stangGT's Avatar
Region: Arkansas
Quick install ?
Hey guys I'm sure it's on here somewhere but I'm changing out coil packs for someone on an 03 GT and and was just looking for a refresher as to how difficult it is.. If i remember correctly it's pretty easy? Like an hour tops?
Bama 93 race tune, bbk o/r xpipe, gt500 axle backs, frpp k-springs, steeda rear lca's, 3d carbon 3d500 wing, boss/cs front fascia w boss brake cooling kit, plenty more...
11stangGT is offline   Reply With Quote
Old 04-17-2014, 04:37 PM   #2
Slow4V's Avatar
Yes should be easy, they are just 8mm bolts , might have to remove anything if it's on top. Like intake .. I don't have a GT anymore but shouldn't be bad.
May have to remove fuel rail ..
Old 04-17-2014, 04:43 PM   #3
11stangGT's Avatar
Region: Arkansas
Ya I had an 03 & an 04 and I thought you had to at least loosen the fuel rail. Just wanted to make sure i wasn't going to regret only charging her $50 lol
Old 04-17-2014, 04:47 PM   #4
FullyAutomatic's Avatar
Region: Mexico
50 bucks to change some chicks cops... nice loool
should take like a minute each.. passenger side just remove the air intake and its simple. especially if they came with the boots and spring all together.
why change them? apparently ford did a good job with the cops. unless there gone bad would be better to leave them no?
FullyAutomatic is offline   Reply With Quote
Old 04-17-2014, 04:50 PM   #5
Mile high JDF's Avatar
I thought they were 7mm bolts? Either way it shouldn't take more than like 10 minutes depending on how fast you go. You don't *need* to loosen the fuel rail but depending on the person it might be easier that way.
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 04-17-2014, 04:51 PM   #6
Region: Mexico
unclip. unscrew. pulls out. swap boot and spring if you have to then put it back on the plug. screw it back on and clip it back in..
keep in mind the boots are pretty flexible .. so pretty easy to get back in
you don't need to remove fuel rail!
Old 04-17-2014, 04:52 PM   #7
11stangGT's Avatar
Region: Arkansas
She had a tune up done on the car and they told her she had a bad one and that it wouldn't be a bad idea to change them all. It also has a SCT livewire on it. That she knows nothing about and was on the car when she got it
Old 04-17-2014, 04:59 PM   #8
Region: Mexico
whats considered a tune up?
plugs, cops, air filter, pcv valve, injectors cleaned, and oil and filter changed?
I see that posted on most shops up around town... Come in for a Tune Up!
lol
Old 04-17-2014, 05:10 PM   #9
11stangGT's Avatar
Region: Arkansas
Just the basics more than likely.. I just finished driving it. Definitely feels like it's got a hell of a miss. Noticed soon as I started it up
Old 04-17-2014, 07:18 PM   #10
11stangGT's Avatar
Region: Arkansas
She wanted me to look at the programmer. I returned it to stock and then put the tune back on.. Won't stay running. Any ideas?
Old 04-17-2014, 07:34 PM   #11
Region: Mexico
lol u made it so her car wont keep running?
Old 04-17-2014, 08:00 PM   #12
11stangGT's Avatar
Region: Arkansas
Apparently? Lol. I returned it to stock and the. Re-downloaded the tune. Not running worth a crap if at all.. So apparently the tune was not correct and needs to be altered. I change the injectors from stock to 30lb and it stays running now but just a lil bit rough.. Any idea?
Old 04-17-2014, 08:16 PM   #13
Region: Mexico
and shes paying you 50 bucks?
wasn't the car running just fine a few hours ago"?
Old 04-17-2014, 08:18 PM   #14
11stangGT's Avatar
Region: Arkansas
Really?! If u can't helpful then don't comment.. The car ran fine before she asked me to look at the tuner
Old 04-17-2014, 08:28 PM   #15
Region: Mexico
sorry man just found it funny.. that's all
cant you just put the factory tune back on?
Old 04-17-2014, 08:30 PM   #16
11stangGT's Avatar
Region: Arkansas
Nope. Won't stay running. There's no telling what's goin on. She told me after I messed w the tuner that the guy she got it from said not to change it. It's running now it just has a small lope to it sorta.
Old 04-17-2014, 11:22 PM   #17
Peterzinyou's Avatar
Just did plugs and coils on mine. Bought the Summit coils because they were red like my car, lol. Definitely notice a little difference in the car.
Sent from my SM-N900T using Mustang Evolution mobile app
ID:	154348   Click image for larger version
Borla S-Type stingers, BAMA SCT tuner, K & N Typhoon CAI, Classic Design Concepts light bar, MACH 1 chin spoiler, MACH 1000 w JVC Kvw 500 HU, plastidipped hood scoop, wing & Premium GT rims, painted calipers, 3.73 gears, black Bullitt fuel door, MMD hood struts, sub-frame connectors, SVE uca & lca, Power Stop drilled/slotted rotors
Peterzinyou is offline   Reply With Quote
Quick question need a quick answer about exhaust manifolds Ghostedmind Pre-2005 V6 Mustang 7 03-14-2013 11:36 PM
how hard to install o/r x pipe? how much to get x pipe install? MustangForEver 2011-2014 Mustang GT 9 02-05-2013 07:01 PM
Quick install question Redstang1 2011-2014 Mustang GT 8 10-25-2012 08:13 PM
help with pulley install quick! MusclesFromBrussels Pre-2005 V6 Mustang 3 08-19-2003 05:58 PM
need to talk to brandon or a mod or admin here quick tire The Bar 15 07-28-2003 07:01 PM
03:13 PM
