Rough Idle After retuning to Stock - Mustang Evolution
Old 04-17-2014, 07:11 PM   #1
PonyBoyV6's Avatar
Just went to the stock tune after having run the 93 race tune for a year. (switched back to stock for emissions) everything ran nicely while it had the 93 tune. Now the idle gurgles and bobbles up and down very slightly, almost like the feeling of a lopy cam. Is there a way to reset the idle on these cars like the newer cars? Hoping that will help.
PonyBoyV6 is offline   Reply With Quote
Old 04-18-2014, 09:53 AM   #2
PonyBoyV6's Avatar
Bumping for quick info
Old 04-18-2014, 11:07 AM   #3
cliffyk's Avatar
With the engine hot disconnect the battery for 5 to 7 minutes to reset the KAM--then let it idle for at least 15 minutes so that the PCM can relearn the idle air and timing trim values.
You may also wish to perform the OBD II drive cycles (read more here), although "normal" driving for 20 to 25 miles will usually get the I/M monitors reset...
Old 04-18-2014, 12:14 PM   #4
PonyBoyV6's Avatar
Great info cliffy, thanks for the link as well
1974 V6 rough idle after new coil installed? Gazelle Classic Mustangs 6 02-08-2015 01:10 PM
Rough idle before throttle body cleaning, worse after 11CharlesB Pre-2005 V6 Mustang 7 09-10-2013 06:21 PM
Stalling/rough idle after start up? brianw64 2011-2014 Mustang GT 11 12-18-2012 07:53 PM
Retuning Klaximilian 2011-2014 Mustang GT 2 11-25-2012 10:13 AM
Rough Idle and Rough Start Cajun JungleBoy Pre-2005 V6 Mustang 3 04-23-2006 10:33 PM
02:39 PM
