Subframe Connectors - Mustang Evolution
Old 04-18-2014, 09:00 PM   #1
Slow4V's Avatar
Subframe Connectors
Okay so next mod ?!
Maybe the subframe connectors full size , welded of course
I was checking out the SVE and the MM and they look so identical .. Wonder if they are the same..
Also this performance shop quoted me for the " biggest and thickest FL subframe sill ever get "
He said 200 for them and installed
Wonder if that's a good price
Old 04-18-2014, 09:12 PM   #2
Stifflers. Get their full subframe system, it has the actual connectors, jacking rails and the subframe matrix.
Old 04-18-2014, 09:30 PM   #3
Mile high JDF's Avatar
Stifflers is a bit excessive in my opinion. All it does is add weight with no real benefit other than lateral rigidity in the event of a major colision.
Slow my only guess for the difference between the two would be fitment. I personally have the MM set on mine and they fit just fine. That being said, I have never seen the SVE on a car before so I can't vouch for their build quality and fitment. $200 sounds about right. Just make sure the shop has a drive on lift to use to weld them in.
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 04-18-2014, 09:36 PM   #4
Depends on what you want. Something like autocross which I do you want it to be stiff as hell.
Old 04-18-2014, 09:44 PM   #5
Regular sub-frame connectors will do just that. Here's my question for you, if the area between the punch welds and frame rails was so weak that it would start to flex under heavy lateral loads then why doesn't everybody else besides Stiffler and Kenny Brown make them? Seems like a waste of money to me, especially since a kit like that is gonna add 20 lbs to the car. I researched a lot about the Stifflers setup before I got my SFCs and came to the conclusion that there is no real benefit to their system on a car like mine. Granted that's just my personal opinion on their kit.
Old 04-18-2014, 09:48 PM   #6
Because race car Click image for larger version
Name:	ImageUploadedByMustang Evolution1397879308.864875.jpg
Old 04-18-2014, 09:57 PM   #7
Slow4V's Avatar
More of street driving, occasionally drag strip
---------- Post added at 10:57 PM ---------- Previous post was at 10:57 PM ----------
Because race car Attachment 154453
Whoa crazy
Old 04-18-2014, 10:08 PM   #8
MM FLSFCs on a local guys car.
http://www.coloradostangs.com/index....ineral-Grey-GT
Page 32 on tapatalk.
Old 04-18-2014, 10:08 PM   #9
Slow4V's Avatar
Wow that's so cool..
Old 04-18-2014, 10:15 PM   #10
Subframe Connectors
I've got MM Full length and mine still doesn't do that I can lift the whole front my the K member but I want to just jack one side and have the entire thing lift.
Subframe connectors Zim Pre-2005 V6 Mustang 15 07-14-2004 11:58 AM
How much to install subframe connectors njstang97 Pre-2005 V6 Mustang 8 02-01-2004 11:42 AM
Subframe connectors? 01mineralgrey6 Pre-2005 V6 Mustang 8 07-22-2003 12:06 AM
06:54 PM
