Squeaking Noise?? - Mustang Evolution
Old 04-19-2014, 12:11 AM   #1
Riverdale's Avatar
Squeaking Noise??
I notice when i drive at a low speed like through parking lots or through a parking garage i hear squeaking noise coming from the front of my car.. happens when i turn the wheel from left to right and it sounds like metal.. maybe ball joints? i know it is not my tie rods because its not a clicking noise when i turn. Anybody have any ideas? When i pull through places i want people to hear me for the right reason (exhaust 👍), not the sound of my car about to break down at any second 👎.
Riverdale is offline   Reply With Quote
Old 04-19-2014, 12:47 AM   #2
I had a sound like that. Check the outer tie rods. Mine were cracked and making lots of noise
wicked2v is offline   Reply With Quote
Old 04-19-2014, 07:35 AM   #3
XSlashDashX's Avatar
Lower ball joints. What I'm going through right now.
Old 04-19-2014, 08:03 AM   #4
cliffyk's Avatar
This (click here) is another possibility...
Old 04-19-2014, 08:06 AM   #5
Squeaking Noise??
Here is what my outer tie rod squeak sounded like http://youtu.be/eZM-lfdV5WE
Old 04-19-2014, 08:51 AM   #6
Riverdale's Avatar
wicked did it also make that sound when you shut the doors and sat in the car sometimes?
Old 04-19-2014, 09:06 AM   #7
Hmm I honestly don't remember. But it did squeak every time I went over a bump or was on uneven pavement
Old 04-19-2014, 09:10 AM   #8
Riverdale's Avatar
alright wicked so you just replaced the tie end rods? i just saw this on my ebay, should i buy?Attachment 154475
Old 04-19-2014, 09:12 AM   #9
Riverdale's Avatar
Name:	ImageUploadedByMustang Evolution1397920338.365020.jpg
Old 04-19-2014, 09:13 AM   #10
You should probably take your tire off and check everything out before you commit to buying anything. The little bushing on the outer tie rod was all cracked and gross on mine
Old 04-19-2014, 09:14 AM   #11
Riverdale's Avatar
alright i'll do that as soon as im off work, thanks man!
Old 04-19-2014, 09:36 AM   #12
Np. If you figure it out you'll prolly pay less and have to do less work.
Work smarter not harder lol
Old 04-19-2014, 10:12 AM   #13
Doe_Rae_mi's Avatar
I'm having the same noise. Can't figure out what it is. Doesn't happen when I turn wheel. Only when I'm going slow just like urs. Also when I close the door it does it. Thought it was the sway bar end links but nope it wasnt
Old 04-20-2014, 07:52 AM   #14
Clean98 Gt's Avatar
In your video it sounds like to me it's the ball joints that are squeaking or could be lower control arm bushings unfortunately Ford had a brilliant idea of not putting grease fittings in the ball joints so there really is no way to Greece them mine was doing the same thing I ended up replacing the ball joints and the lower control arm bushings cause I had the car up there anyway once I replace those the squeaking went away I'm not sure if it was coming from the ball joint on the lower control arm bushing but the parts were pretty cheap. Good luck
Clean98 Gt is offline   Reply With Quote
Old 05-01-2014, 01:23 PM   #15
phillip433's Avatar
Squeaking Noise??
Mine squeaks when I turn the wheel left. Anytime I turn left it squeaks. Some say it's rack and pinion but Idk. I tried looking to see where the sound comes from but I can't tell.
phillip433 is offline   Reply With Quote
Old 05-01-2014, 05:56 PM   #16
V6 stang's Avatar
Mine squeals too. You can hear it through tunnel or up against walls pretty bad lol. Front right bushing and rack n pinion need replaced. Professional noticed it when I got an aligbment
2012 Mustang GT Convertible
Roush Exhaust
2003 Mustang GT (Sold)
Old 05-01-2014, 08:15 PM   #17
phillip433's Avatar
If it's the rack and pinion. You would have to pretty much take the whole engine out huh?
Old 05-01-2014, 08:36 PM   #18
Sounds like ball joints...
txffmike is offline   Reply With Quote
Old 05-03-2014, 10:55 PM   #19
Has to be ball joints. Ask me how I would know, lol.
Name:	ImageUploadedByMustang Evolution1399179145.922797.jpg
ID:	155810Click image for larger version
Name:	ImageUploadedByMustang Evolution1399179193.076593.jpg
Old 05-04-2014, 12:05 AM   #20
Riverdale's Avatar
jesus christ bro lmao
Old 05-04-2014, 09:51 AM   #21
Heard the noise when I close the door, go over speed bumps, and when I turn the wheel left or right. Finally the ball joint gave out in the parking lot and not down the road.
Old 05-04-2014, 12:13 PM   #22
Riverdale's Avatar
yeah that you're blessed u werent driving.. how long did you hear the noise before it gave out on you?
Old 05-04-2014, 02:17 PM   #23
4 months.
Old 05-05-2014, 08:19 AM   #24
phillip433's Avatar
Damnnnn.
bad squeaking noise on 3.8 01' mustang jumpman1203 Pre-2005 V6 Mustang 9 07-27-2015 01:03 AM
Squeaking noise coming from belts sLbxO143 1996-2004 Mustang GT 11 02-25-2013 02:08 PM
weird squeaking noise 86 muscle 1996-2004 Mustang GT 8 10-08-2011 03:23 PM
Squeaking noise Nog51 Pre-2005 V6 Mustang 13 12-21-2010 09:18 AM
Squeaking Noise joekool9 Pre-2005 V6 Mustang 3 08-03-2004 09:38 AM
09:30 PM
