New clutch in 97 gt - Mustang Evolution
Old 04-19-2014, 11:21 PM   #1
tinkercameron's Avatar
New clutch in 97 gt
I want to put a new clutch in my 97 gt. It doesn't let out until almost the top. How hard is it to replace one? And does anyone have any suggestions on what to look for?
tinkercameron is offline   Reply With Quote
Old 04-19-2014, 11:28 PM   #2
Slow4V's Avatar
Could just be the cable
Old 04-20-2014, 12:04 AM   #3
Have you tried adjusting the cable quadrant by firmly pulling up on the clutch pedal until you feel it release, and then slowly pushing the clutch pedal all the way to the floor?
The clutch replacement is relatively easy providing that you have the proper tools, expertise, and time to do the job correctly.
Old 04-20-2014, 12:14 AM   #4
No i havent looked into just a cable. Is it relatively easy to replace?
Old 04-20-2014, 12:16 AM   #5
A hell of a lot easier than the clutch!
Try adjusting it first...
Old 04-20-2014, 12:17 AM   #6
Ill do that. Thanks for the advice!
Old 04-20-2014, 12:18 AM   #7
No problem!
Old 04-22-2014, 06:46 AM   #8
Grab your clutch pedal firmly in your hand and yank UP towards you. You should hear a zipping sound like a zip tie. This is the pawl on the stock quadrant taking out the slack in the cable. Now try working the pedal and see how it feels. Not saying this will fix it but if your cable is stretched over time that could be it. Although generally a stretched cable will mean it won't start to engage at all until it gets near the floor, not up top.
If you DO replace the cable, DO NOT USE A PARTS STORE CABLE. They are NOT the same as an OEM cable and they WILL bind and usually snap after not too long. You want an OEM style cable which you can get from Maximum Motorsports or your local Ford dealer.
Old 04-22-2014, 11:34 AM   #9
You can acquire a quality cable from MM's included with their quadrant and adjuster.
MM Clutch Cable, Universal Mustang, Ford OEM, 1982-04
Clutch adjuster, clutch, or tranny Elcobrachingom SVT Mustang 3 09-05-2012 06:32 PM
clutch slipping and new clutch? iphonemaster93 Pre-2005 V6 Mustang 29 08-06-2012 09:37 AM
clutch clutch... clutch Butch SVT Mustang 4 06-29-2012 03:53 PM
just installed new clutch ram hdx drove about 5 miles and clutch got really hard? Cobra209 SVT Mustang 11 04-01-2012 04:44 PM
Dual Clutch Vs Single Clutch 504 Stang Rida 1996-2004 Mustang GT 7 11-29-2011 07:22 PM
04:59 PM
