Lowering the Roush - Mustang Evolution
Old 04-20-2014, 09:51 PM   #1
The_Chech's Avatar
Lowering the Roush
Tomorrow I begin the process of lowering my Roush stage I tomorrow, to get rid of the horrendous wheel gap and tighten up the handling a bit. I have every thing I need tomorrow to try and get this done( I THINK). I've done suspension work before but mainly lifting SUV's, Jeeps and one Accord (lowered) my friend had. I've watched countless videos so I know what to prepare my self for (I HOPE)! It honestly looks very straight forward and much easier to do then torsion bar set ups and coil over strut setups. but as always easy things tend to back fire for me
Just wondering if I should start on the front first or the rear and what problems I should be ready to face trying to replace struts, shocks, springs and the caster camber plates.
I already have 1 jack and 2 jack stands but I'm debating to go out and get more of each or should I just try and tackle one end at a time ( front then rear or rear then front). Every thing has been PB'ed days prior so hopefully I don't run into and frozen bolts.
Do you think I'm set?
The_Chech is offline   Reply With Quote
Old 04-20-2014, 10:14 PM   #2
Slow4V's Avatar
Rear is super easy
Maybe 30 min for both sides
Front is easy too just little hard sometimes to remove spring out of arm
Old 04-20-2014, 10:29 PM   #3
The_Chech's Avatar
Even with out air tools and possibly just my self?
Old 04-21-2014, 01:14 PM   #4
The_Chech's Avatar
So far so good on the front just waiting on FedEx to get here with my spring isos then I can bolt every thing up again and start on the rear. Don't wanna get ahead of my self but I'm amazed on how easy the whole front end was, blew me away!
Oxford White Roush Stage 1 SN# 6925--SOLD but never forgotten!
Kona Blue GT premium - Slammed on BC's and BMR's full rear suspension
Old 04-21-2014, 01:25 PM   #5
FullyAutomatic's Avatar
Region: Mexico
should post pics and details so others can search how to change there springs shocks and struts...
FullyAutomatic is offline   Reply With Quote
Old 04-21-2014, 05:25 PM   #6
Slow4V's Avatar
Yes , I always prefer air tools , but it can be done without ..
Old 04-22-2014, 05:46 PM   #7
1lowGT's Avatar
It can be done by yourself and with hand tools, I only use air gun to take the lug nuts off then hand tools for everything else. If it is your first time then it may take a little longer but not bad at all. The rear is the easiest, just lift the car up support the axle and undo the bottom of the shocks and then lower the axle till you can get the springs out. Front is easy too, just a little more things to undo and a springs compressor isn't needed but will make it a lot easier I got the one for macpherson style and used it helps out a little.
Old 04-22-2014, 10:42 PM   #8
The_Chech's Avatar
Yesterday was pretty easy I have to say every thing came out very well and went back in just the same. Except for the right tie rod end but a quick run to auto zone for a new one and the front was done. The rear was sooo easy! skipped the whole step of removing the rear sway bar and just did both lower control arms at the same time probably took 30 minutes to do the whole rear end. I also found out either the dif cover or gasket has gone bad some how and now my diff is leaking. Now I know where the tiny oil spots are coming from in the drive way
2011-2013 Dub Roush/Eibach lowering springs Rolltide Mustang Parts for Sale and Wanted 3 08-05-2012 10:08 PM
Roush Mustang GT - Current Mustang :: 2003 Ford - Roush GT - Roush Stage 2 Tib Member Garages 0 06-15-2011 12:01 PM
Lowering Roush? StgRsh General Mustang Discussion 20 03-18-2010 09:43 PM
Roush 427R Most Powerful Roush Ever Brent General Mustang Discussion 14 10-27-2006 08:56 PM
07:37 PM
