EGR delete - Mustang Evolution
Old 04-21-2014, 08:12 AM   #1
Slow4V's Avatar
EGR delete
Was going to do long tubes , but was wondering if it's a smart idea to just delete my egr so I don't have to go through the trouble of it.
But what if I just plug the egr ports up? And leave it like that, would my car act up?
Old 04-21-2014, 09:02 AM   #2
Brentap19506's Avatar
I'm not too sure about plugging up the ports but I imagine that it would work the same as getting the block off plate. I got the block off plate for $10 and just got rid of the whole thing. It was really easy and looks much better. Just need to have a tuner to rid of the check engine light
2000 Gt- Vortech V1 10psi, 4.10 gears, SLP LT headers, Magnaflow cat-back, Eibach pro-sport suspension, MM subframes, 78mm plenum and throttle body, lots of cosmetics, and more
Brentap19506 is offline   Reply With Quote
Old 04-21-2014, 09:04 AM   #3
FullyAutomatic's Avatar
Region: Mexico
benefits?
FullyAutomatic is offline   Reply With Quote
Old 04-21-2014, 09:06 AM   #4
Slow4V's Avatar
Benefit is time saved
Old 04-21-2014, 09:11 AM   #5
Theres not much benefit at all besides having a cleaner engine bay and saving headaches by not dealing with the annoying EGR system. Sometimes the EGR system goes bad, throws codes, and has to be replaced. Instead of spending $100 to replace it, you just delete it for $10.
When you put headers in your car, you have to mess with the EGR so it's easiest just to delete it altogether.
Old 04-21-2014, 11:03 AM   #6
Slow4V's Avatar
Will my car act funny with no egr system and no tune ?
Old 04-21-2014, 05:21 PM   #7
Yes it could act up with the EGR system not working and the computer looking for it. I don't see the point to delete it. No benefit except a cleaner engine bay and these modular EGRs are not bad at all.
Old 04-21-2014, 05:23 PM   #8
Slow4V's Avatar
Well I was going to do longtubes but wonder if it would be a pain to keep the EGR system, I heard the pipe that runs from the manifold to intake can be a pain
Old 04-21-2014, 05:24 PM   #9
Cut it, keep the end pieces and route some heater hose however you need to and hook it back up.
Old 04-21-2014, 05:31 PM   #10
Slow4V's Avatar
Hmmm can you show me a example ?
Like cut the pipping tube and run a rubber hose ?
Old 04-21-2014, 05:42 PM   #11
Without a tune I wouldn't bother deleting the system. I only did it because I knew I wouldn't run into any problems with my tuner.
Without a tune your car will think something is really wrong with your exhaust and try to compensate for it.
Old 04-21-2014, 05:45 PM   #12
Slow4V's Avatar
Old 04-21-2014, 05:58 PM   #13
Just my personal experience with 5.0s. I did it to keep the smog pumps if I still had cats but to get rid of all the rear crossover crap. Cut the end off the EGR pipe, clamp it to a heater hose, do the same for the other end and route it so it doesn't kink and hold it in place with zip ties. Not the prettiest but functional.
Old 04-21-2014, 07:56 PM   #14
Region: Mexico
egr delete
EGR delete concerns sledgehammer Pre-2005 V6 Mustang 14 01-07-2010 11:52 PM
egr delete kit Dark02Pony Pre-2005 V6 Mustang 17 05-29-2005 09:58 PM
egr delete InVaDeR Pre-2005 V6 Mustang 18 11-23-2004 09:05 PM
EGR delete kits plus other stuff for sale 97Stallion Mustang Parts for Sale and Wanted 0 05-27-2004 08:15 PM
EGR delete kits Stylin97V6 Mustang Parts for Sale and Wanted 8 03-05-2004 09:04 AM
03:58 AM
