Ticking sound - Mustang Evolution
Old 04-22-2014, 07:11 PM   #1
robin_gt's Avatar
Ticking sound
Alright so a couple days ago this ticking sound started but it only occurs if the engine is warm and only if i let the engine idle. The ticking sounds like it comes from the engine.
robin_gt is offline   Reply With Quote
Old 04-22-2014, 07:37 PM   #2
When your engine is cold, check your sparkplugs. The 4.6s are known for spark plug blow out from them backing out. The ticking is the warning before the launch. Don't over tighten them, check each one and tighten/torque as needed.
Bigshow14 is offline   Reply With Quote
Old 02-28-2015, 11:51 AM   #3
Gt Byron's Avatar
Could also be a timing chain
Gt Byron is offline   Reply With Quote
Old 03-02-2015, 04:40 PM   #4
mustangt03's Avatar
sparkplug
mustangt03 is offline   Reply With Quote
Old 03-02-2015, 10:52 PM   #5
alecas447's Avatar
If It was s bad plug, I think the car would misfire.
I replaced my clutch about 6 months ago, and I still get a ticking and chattery noise from the throw out bearing.
alecas447 is offline   Reply With Quote
Old 03-03-2015, 04:40 PM   #6
mustangt03's Avatar
Mine wasn't misfiring when I had a plug pop out. The way I found it is when the car was running I put my finger on each coil and felt a tapping on one lol. Took it off and sure enough it was loose.
As for the clutch chattering I think its common in these cars from what iv read.
Old 03-03-2015, 04:54 PM   #7
fenixignition's Avatar
ticking could be a number of things, not just the spark plugs. I would definitly monitor them to make sure its not a loose plug, and torque them correctly. but it could easily be from a timing chain guide or a stuck valve.
2002 GT 5sp. 16x,xxx miles
Ticking sound PonyBoyV6 Pre-2005 V6 Mustang 8 05-15-2012 04:17 PM
ticking sound under my car? Vile87 Pre-2005 V6 Mustang 29 03-04-2012 07:42 PM
Rattling/ ticking sound? SHADOWX777 Pre-2005 V6 Mustang 1 11-11-2011 07:13 PM
Ticking sound??? BigSteve305 Pre-2005 V6 Mustang 30 03-21-2011 01:45 PM
ticking/ knocking sound almostxevil Pre-2005 V6 Mustang 16 04-04-2007 06:29 PM
09:48 AM
