engine issue - Mustang Evolution
Old 04-22-2014, 07:41 PM   #1
engine issue
Can a up stream oxygen sensor cause the engine to perform badly without the check engine light on? I have a 2000 gt with a kb that acts like it's missing firing on take off causal driving not racing. But when you race it does fine. Also it acts up seems like when the engine gets hott but you Un plug the maf sensor and drive it down the street not w/o throttle it doesn't do it. Any thoughts ?
southernstang00 is offline   Reply With Quote
Old 04-22-2014, 10:26 PM   #2
I had a lazy upstream sensor that was resulting in hesitation and stalling out with no CEL, so I guess it's possible
Old 04-22-2014, 10:42 PM   #3
Was their a certain point as to when it would do it ? I'm thinking I'm going to buy one and see which side it is. Because this car was running good no issues at all. Someone said they may think the air fuel ratio is off but I don't see how when it was running good on the tune before.
Old 04-22-2014, 11:55 PM   #4
I think your right, a guy at work brought up a good point. Not too long ago my intercooler busted sending coolant into the exhaust, about 2 gals worth between both sides coming out the tail pipe. Didn't hurt the motor but I agree with you and him the upstream sensors more then likely got soaked with coolant.
Old 04-23-2014, 12:49 AM   #5
Mfore33's Avatar
I've got a 2000 gt auto and I had a similar problem. Lower mpg and a stumble on takeoff. I replaced both upstream o2 sensors and did the idle relearn and that fixed it. I got my sensors from rock auto. They were the factory ones for way cheaper than anyone else. I also had no engine codes.
Old 04-23-2014, 01:09 AM   #6
Thanks the the info think I'm going to do that.
Old 04-23-2014, 06:25 AM   #7
Mine would stall out almost Everytime after cruising over 45mph and then coming to a stop, especially like when getting off at an interstate ramp.
I had purchased the Torque app and a blue tooth obd2 reader. Once I wad able to data log it and see my fuel trims ask jacked up it was obvious to me one of my upstream sensors was on its way out (my rears are turned off).
I replaced both of the upstream ones just to be safe and did the idle élan which was Baidu unconnecting the battery for like 15 min. That was a year ago running smooth since
Old 04-23-2014, 11:14 AM   #8
This problem started every since my intercooler busted soaking my exhaust so I think I'm going to do what you did and see if that fixes it.
engine light issue. Matt3422 2011-2014 V6 Mustang 2 02-22-2013 06:44 PM
Check engine light issue,need help! Israel98 1996-2004 Mustang GT 132 12-07-2012 08:31 PM
Issue with flywheel on an engine swap awwphooey 1996-2004 Mustang GT 10 10-15-2012 04:27 AM
Was the 351C engine package a stock issue in the 1971 Mustang? jeffery Classic Mustangs 2 12-14-2011 11:44 PM
Engine noise from COLD engine 03GreyMach1 1996-2004 Mustang GT 10 03-14-2008 07:40 PM
08:54 AM
