Replace bearings - Mustang Evolution
Old 04-23-2014, 12:54 AM   #1
Speed_Mister's Avatar
Region: Arkansas
Replace bearings
So my rear bearings are going bad I can hear them, not to bad but do y'all suggest replacing just the bearing and seal or the whole hub assembly? And any insight on how to replace the bearings?
2004 Mustang GT 5 Speed
Full Bolt Ons
370rwhp 470rwtq
12.1 @ 117.9 (1.7) in 1/4th
7.6 @ 92.1 (1.6) in 1/8th
Old 04-23-2014, 06:20 AM   #2
Slow4V's Avatar
You have to get them pressed on I believe
Old 04-23-2014, 11:28 AM   #3
FullyAutomatic's Avatar
Region: Mexico
just did my front... its a whole hub assembly cant do just the bearings|
not sure about the back
FullyAutomatic is offline   Reply With Quote
Old 04-23-2014, 11:47 AM   #4
You can put a torch on the axle tube when the axle is out and its empty and have the bearings in the freezer overnight. Once the axle gets hot you have a helper with a big socket/hammer ready to go (both wearing thick gloves) stuff that freezing bearing into the axle and tap it into place.
He's talking about the back. Axle has to come out, bearing puller, new bearing in, re-assemble.
Now is a good time for new diff fluid and would also be a great time to install Cobra/Mach/Bullitt caliper bracket brackets on the axle so you can run the bigger vented rotors out back.
Old 04-23-2014, 05:26 PM   #5
Region: Arkansas
You can defiantly just replace the bears just to see if it fixes the noise. But it sounds pretty straight forward. Take off wheels, brakes and bracket, rotor, take off rear diff cover take out pins that hold the axle in place pull axle out take out the bearings replace them by tapping and reassemble, re-lube diff. And friction modifier. Which ones would y'all recommend to replace inners or outer. Or both?
Full Bolt Ons
370rwhp 470rwtq
Old 04-23-2014, 05:30 PM   #6
Region: Arkansas
And re-silicone differential cover. I may need help to identify where the bearing are it's been a while since I built my rearend with my friend like ~3 years ago maybe 2.
Full Bolt Ons
370rwhp 470rwtq
front wheel bearings 98mustang2007 1996-2004 Mustang GT 1 08-20-2010 10:19 AM
im about to replace my clutch/flywheel what else should i replace? 1996v6stang Pre-2005 V6 Mustang 2 07-12-2010 11:22 AM
Wheel Bearings Mustang1804 1996-2004 Mustang GT 12 04-11-2010 11:05 AM
bearings/ball joints in the rear tigerfan2771 Pre-2005 V6 Mustang 5 08-06-2008 07:19 AM
Wheel Bearings? Thomas91169 Mustang Wheels & Tires 6 09-06-2006 12:11 AM
05:41 AM
