03 mustang gt 4.6 inspection problem - Mustang Evolution
Old 04-24-2014, 05:50 PM   #1
Hello all, New guy on the block and in need of help? Took my mustang to get inspected I live in NY and when they would hook it up to there computer it would start going and then it would stop and say disconnect. Checked my fuse which was good and car runs perfect. Any help would be thankful.
03 mustang gt is offline   Reply With Quote
Old 04-24-2014, 07:19 PM   #2
FullyAutomatic's Avatar
Region: Mexico
what?.. for emissions?
uhhh if you were at a shop. shouldn't they of told you what is wrong?
details...
FullyAutomatic is offline   Reply With Quote
Old 04-24-2014, 07:30 PM   #3
As they were performing the inspection they need to hook my car up to there machine which would start then suddenly stop. They said being they couldn't read my cars computer they couldn't inspect.
Old 04-25-2014, 10:23 PM   #4
Take it to a different station. They may have had a flaky machine or a bad cable. If it happens at the next shop ask wtf is going on and go from there. You might have a loose wire in/around the OBD2 plug too although I've NEVER heard of this sort of thing happening.
Old 04-26-2014, 05:03 AM   #5
I did take it to a different shop with same results. Seems when I have a problem its one that can't be explained. The only thing that has happened while taking it out of storage was my after market stereo was on and all of a sudden it made a pop threw my speakers and turned off. Turned back on. Is there any other fuses to check besides the data #31 under my steering wheel? Thanks for replys in my wtf situation.
Old 04-26-2014, 08:21 AM   #6
Check all the fuses at the fuse box under the dash. That pop you heard was something blowing so you have somthing that needs replacing. Also I would double check your stereo installation and all your grounds.
Old 04-26-2014, 11:16 AM   #7
Region: Mexico
oh and find some competent mechanics lol
do they just shrug there shoulders and say .. I donno bro.
wtf lol seems weird to me.
Old 04-27-2014, 01:27 PM   #8
Hello, Just checked all fuses which checked out good. Removed stereo and found 3 wires from a connector from car to stereo had black tape and additional wire wrapped on them. Looks like coating on wire was cut. Could that bethe problem? For the mechanics around here can't find any good ones that are honest and know anything. Thanks for all your help! Joe
Old 04-28-2014, 12:42 PM   #9
cliffyk's Avatar
What colour are the wires?
Old 05-01-2014, 08:27 AM   #10
Brought car to a mustang mechanic. Will post problem when I hear something. Thanks to all
Problem getting my inspection sticker 92mustang2.3 2011-2014 Mustang GT 12 09-27-2013 02:40 PM
Mustang 66 failed state inspection Mustana Classic Mustangs 2 03-17-2012 08:39 PM
If I purchase a 1965 Mustang Fastback in N.J. can it pass inspection? cuarto Classic Mustangs 3 08-26-2009 05:16 AM
So my 89 failed inspection... MonteCitan The Bar 18 07-05-2005 10:51 PM
I dominated emissions in my second inspection wiarumas The Bar 4 02-17-2005 04:11 PM
10:10 PM
