Help with crank 02 mustang gt 4.6l - Mustang Evolution
Old 04-27-2014, 09:35 AM   #1
Chadillac34's Avatar
Region: Delaware
Ok so I'm replacing the rod bearings and main bearings. My problem is when I take out the bolts that hold the crank in how do I get the bottom clamp off to put in the new bearings?? 02 Mustang gt 4.6l
Chadillac34 is offline   Reply With Quote
Old 04-27-2014, 09:39 AM   #2
Region: Delaware
Name:	ImageUploadedByMustang Evolution1398613125.717136.jpg
The bolts you see right there that hold on the clamp that holds the crank in place. One I take out those bolts the clamp won't move. How do I get them out??? First timer here lol
Old 04-27-2014, 10:09 AM   #3
There are 4 bolts holding the main caps in place, two that run vertically and two horizontally. You'll probably have to carefully pry them off. Dont mix up any of the caps, they need to go back in the same place.
Again, I recommend getting a repair manual. It has all of the information in it to do this correctly.
95 mustang crank sensor?????? jennaeM95 Pre-2005 V6 Mustang 0 02-11-2013 09:26 AM
little help needed on adjustable crank gears! mhobbs 1996-2004 Mustang GT 1 05-17-2012 12:38 PM
1999-00 Mustang 3.8L Underdrive Crank Pulley CHILE10_STANG Pre-2005 V6 Mustang 3 05-16-2011 09:39 AM
Where is the crank position sensor on a 2002 mustang 3.8l? colton Pre-2005 V6 Mustang 1 08-25-2009 10:57 AM
Crank Yankers Ken The Bar 5 05-12-2003 08:32 AM
» Members Mustangs
JM
blue
Haillie
brianw64
Add your Mustang
01:15 PM
