1998 ford mustang gt 5 speed transmission problem - Mustang Evolution
Old 04-27-2014, 09:36 AM   #1
Region: Iowa
I drive a 1998 ford mustang gt 5 speed convertible and im having third gear Grinding problems. i was driving it and i downshifted fast to avoid hitting a car, well i ended up going into the ditch and bottoming out and it was in third gear. Now everytime i shift it into third gear(either upshift or downshift) it grinds but only if i shift fast. If you count to 3 then shift it into third gear it dont grind. People have told me shift linkage, some people have told me syncro, i just wanna get it fixed for my son to drive and i cant figure it out. I dont wanna have to get a rebuild kit if i dont need to
98fordmustangGT is offline   Reply With Quote
Old 04-27-2014, 10:17 AM   #2
This is a VERY common problem. The only thing that you can try, before a rebuild, is to drain and refill the trans with Mobil 1 synthetic ATF or Pennzoil Syncromesh, and see if that helps.
Old 04-27-2014, 03:48 PM   #3
Check your clutch adjustment and you could change the fluid and see if that helps but 96-98 transmissions are notorious for synchros going out. My 98 does the same thing into 2nd and its the synchro. I am replacing it with a 3650 next week. That's what happens when the transmission has paper blocker rings instead of carbon fiber that the 99-up ones got.
Transmission(5-speed to 6-speed) 01mineralgreyv8 1996-2004 Mustang GT 12 05-29-2013 05:58 PM
What type of transmission does my ford mustang gt have 1998? Fferyll 1996-2004 Mustang GT 1 12-24-2011 12:13 AM
Would a 1998 mustang gt engine fit in a 1998 v6 engine bay? imported_Buster 1996-2004 Mustang GT 1 12-14-2011 06:19 PM
1998 Mustang SVT Cobra speed???????? Kenrik General Mustang Discussion 3 03-29-2010 10:28 AM
What Type of transmission does Ford Mustang GT 5.0 have (1995-1998)? Branwel 1979-1995 Mustang GT 9 03-05-2010 07:58 AM
07:59 AM
