Pvc issues - Mustang Evolution
Old 04-28-2014, 12:34 AM   #1
Pvc issues
My 2001 2v wont idle correctly with a standard pvc valve. I got a oem replacement from AutoZone w/the 2 outlets one for the hose to the plenum and another that is capped off.
The only way to keep my car running after letting off the gas was to take the cap off the second outlet and put a mini breather filter on it. Its still connected to the plenum..
Any ideas what might be causing the issues?
Ive tried a few different pvc valves, I even swapped out the stock hose to the plenum with pvc hose. I'm a little stuck.
Fresh air filter and cleaned up tb.
I haven't tried cleaning the maf yet.
2v with bbk intake in the fender, and 75mm tb.
Thanks for looking
Sent from my SPH-L710 using Mustang Evolution mobile app
19robby2 is offline   Reply With Quote
Old 04-28-2014, 12:35 AM   #2
It was a quick temp fix but my engine is sucking in a lot of air
Old 04-28-2014, 01:09 AM   #3
Mfore33's Avatar
Your iac is bad.
Old 04-28-2014, 01:28 AM   #4
I was starting to think that may have been the cause. I'll look into it, thanks
Old 04-28-2014, 01:29 AM   #5
I'm still shocked it hasnt thrown any service engine light tho, been running it lole that for months
Old 04-28-2014, 01:50 PM   #6
Replaced it today, running good with a standard pvc now, thanks alot man, I was tired of hearing that hiss under my hood
Old 04-28-2014, 02:42 PM   #7
Positive Crankcase Ventilation=PCV
Glad you got it fixed!
Old 04-28-2014, 10:42 PM   #8
Mfore33's Avatar
Np
Pvc cold air intake???? SN95V600 Pre-2005 V6 Mustang 19 01-26-2013 03:16 PM
Oil coming threw pvc valve Chefnick 1979-1995 Mustang GT 6 06-16-2012 09:13 PM
PVC delete part II 97Stallion Pre-2005 V6 Mustang 1 08-30-2004 06:57 AM
Did the PVC delete Mod!!!! Danger Dude Pre-2005 V6 Mustang 13 08-20-2004 02:14 PM
I have serious issues n8r The Bar 23 10-17-2003 12:33 PM
08:13 PM
